{"name":"Professionisti del Suono","description":"Il sito dell&#039;alta fedelt\u00e0","url":"https:\/\/www.professionistidelsuono.net\/blog_audio","home":"https:\/\/www.professionistidelsuono.net\/blog_audio","gmt_offset":"0","timezone_string":"","page_for_posts":0,"page_on_front":805,"show_on_front":"posts","namespaces":["oembed\/1.0","akismet\/v1","aioseo\/v1","contact-form-7\/v1","jetpack\/v4","jetpack\/v4\/stats-app","jetpack\/v4\/blaze-app","jetpack\/v4\/blaze","google-site-kit\/v1","jetpack\/v4\/import","wpcom\/v2","jetpack-boost\/v1","my-jetpack\/v1","jetpack\/v4\/explat","wpcom\/v3","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L'URL della risorsa da cui recuperare i dati oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L'URL della risorsa da cui recuperare i dati oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"Il formato oEmbed da utilizzare.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"La larghezza massima in pixel del frame incorporato.","type":"integer","default":600,"required":false},"maxheight":{"description":"L'altezza massima in pixel del frame incorporato.","type":"integer","required":false},"discover":{"description":"Se eseguire una richiesta esplorativa di oEmbed per provider non autorizzati.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/oembed\/1.0\/proxy"}]}},"\/akismet\/v1":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"akismet\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/akismet\/v1"}]}},"\/akismet\/v1\/key":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Una chiave API Akismet di 12 caratteri. Disponibile su akismet.com\/account","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/akismet\/v1\/key"}]}},"\/akismet\/v1\/settings":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"akismet_strictness":{"type":"boolean","description":"Se impostato su true, Akismet scarter\u00e0 automaticamente lo spam peggiore piuttosto che spostarlo nella cartella di spam.","required":false},"akismet_show_user_comments_approved":{"type":"boolean","description":"Se \u00e8 impostato su \"true\", mostra nella pagina dei commenti il numero di commenti approvati accanto ad ogni autore. ","required":false},"akismet_enable_mcp_access":{"type":"boolean","description":"Se vero, consenti ai client MCP di accedere ai dati e alle funzionalit\u00e0 di Akismet.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/akismet\/v1\/settings"}]}},"\/akismet\/v1\/stats":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"type":"string","description":"Lasso di tempo per recuperare le statistiche. Opzioni: 60-giorni, 6-mesi, tutti","default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/akismet\/v1\/stats"}]}},"\/akismet\/v1\/stats\/(?P<interval>[\\w+])":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"description":"Lasso di tempo per recuperare le statistiche. Opzioni: 60-giorni, 6-mesi, tutti","type":"string","required":false}}}]},"\/akismet\/v1\/alert":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"key":{"type":"string","description":"Una chiave API Akismet di 12 caratteri. Disponibile su akismet.com\/account","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Una chiave API Akismet di 12 caratteri. Disponibile su akismet.com\/account","required":false}}},{"methods":["DELETE"],"args":{"key":{"type":"string","description":"Una chiave API Akismet di 12 caratteri. Disponibile su akismet.com\/account","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/akismet\/v1\/alert"}]}},"\/akismet\/v1\/webhook":{"namespace":"akismet\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/akismet\/v1\/webhook"}]}},"\/aioseo\/v1":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"aioseo\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1"}]}},"\/aioseo\/v1\/options":{"namespace":"aioseo\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/options"}]}},"\/aioseo\/v1\/ping":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ping"}]}},"\/aioseo\/v1\/post":{"namespace":"aioseo\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/post"}]}},"\/aioseo\/v1\/post\/(?P<postId>[\\d]+)\/first-attached-image":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/aioseo\/v1\/user\/(?P<userId>[\\d]+)\/image":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/aioseo\/v1\/tags":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/tags"}]}},"\/aioseo\/v1\/search-statistics\/url\/auth":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/search-statistics\/url\/auth"}]}},"\/aioseo\/v1\/search-statistics\/url\/reauth":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/search-statistics\/url\/reauth"}]}},"\/aioseo\/v1\/writing-assistant\/keyword\/(?P<postId>[\\d]+)":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/aioseo\/v1\/writing-assistant\/user-info":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/writing-assistant\/user-info"}]}},"\/aioseo\/v1\/writing-assistant\/user-options":{"namespace":"aioseo\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/writing-assistant\/user-options"}]}},"\/aioseo\/v1\/writing-assistant\/report-history":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/writing-assistant\/report-history"}]}},"\/aioseo\/v1\/seo-analysis\/competitors":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-analysis\/competitors"}]}},"\/aioseo\/v1\/spell-checker\/safe-words":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/spell-checker\/safe-words"}]}},"\/aioseo\/v1\/ai\/image-generator":{"namespace":"aioseo\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/image-generator"}]}},"\/aioseo\/v1\/ai\/insights\/reports":{"namespace":"aioseo\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/insights\/reports"}]}},"\/aioseo\/v1\/ai\/insights\/reports\/(?P<uuid>[a-zA-Z0-9-]+)":{"namespace":"aioseo\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/aioseo\/v1\/seo-checklist":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist"}]}},"\/aioseo\/v1\/seo-checklist\/completed":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist\/completed"}]}},"\/aioseo\/v1\/ai-agents\/mcp-adapter\/release":{"namespace":"aioseo\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai-agents\/mcp-adapter\/release"}]}},"\/aioseo\/v1\/seo-alerts\/test-email":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-alerts\/test-email"}]}},"\/aioseo\/v1\/seo-alerts\/test-slack":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-alerts\/test-slack"}]}},"\/aioseo\/v1\/ai\/auth":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/auth"}]}},"\/aioseo\/v1\/ai\/credits":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/credits"}]}},"\/aioseo\/v1\/ai\/meta\/title":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/meta\/title"}]}},"\/aioseo\/v1\/ai\/meta\/description":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/meta\/description"}]}},"\/aioseo\/v1\/ai\/faqs":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/faqs"}]}},"\/aioseo\/v1\/ai\/schema":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/schema"}]}},"\/aioseo\/v1\/ai\/key-points":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/key-points"}]}},"\/aioseo\/v1\/ai\/social-posts":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/social-posts"}]}},"\/aioseo\/v1\/ai\/assistant":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/assistant"}]}},"\/aioseo\/v1\/ai\/image\/alt":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/image\/alt"}]}},"\/aioseo\/v1\/ai\/truseo\/suggest":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/truseo\/suggest"}]}},"\/aioseo\/v1\/ai\/truseo\/optimize-post":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/truseo\/optimize-post"}]}},"\/aioseo\/v1\/ai\/truseo\/spelling":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/truseo\/spelling"}]}},"\/aioseo\/v1\/ai\/deactivate":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/deactivate"}]}},"\/aioseo\/v1\/htaccess":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/htaccess"}]}},"\/aioseo\/v1\/post\/(?P<postId>[\\d]+)\/disable-primary-term-education":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/post\/(?P<postId>[\\d]+)\/disable-link-format-education":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/post\/(?P<postId>[\\d]+)\/update-internal-link-count":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/post\/(?P<postId>[\\d]+)\/tru-seo-highlighting":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/post\/(?P<postId>[\\d]+)\/process-content":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/posts-list\/load-details-column":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/posts-list\/load-details-column"}]}},"\/aioseo\/v1\/posts-list\/update-details-column":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/posts-list\/update-details-column"}]}},"\/aioseo\/v1\/terms-list\/load-details-column":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/terms-list\/load-details-column"}]}},"\/aioseo\/v1\/terms-list\/update-details-column":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/terms-list\/update-details-column"}]}},"\/aioseo\/v1\/keyphrases":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/keyphrases"}]}},"\/aioseo\/v1\/analyze":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/analyze"}]}},"\/aioseo\/v1\/analyze-headline":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/analyze-headline"}]}},"\/aioseo\/v1\/analyze-headline\/delete":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/analyze-headline\/delete"}]}},"\/aioseo\/v1\/analyze\/delete-site":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/analyze\/delete-site"}]}},"\/aioseo\/v1\/clear-log":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/clear-log"}]}},"\/aioseo\/v1\/connect":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/connect"}]}},"\/aioseo\/v1\/connect-pro":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/connect-pro"}]}},"\/aioseo\/v1\/connect-url":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/connect-url"}]}},"\/aioseo\/v1\/backup":{"namespace":"aioseo\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/backup"}]}},"\/aioseo\/v1\/backup\/restore":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/backup\/restore"}]}},"\/aioseo\/v1\/email-debug-info":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/email-debug-info"}]}},"\/aioseo\/v1\/notification\/email-reports-enable":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/email-reports-enable"}]}},"\/aioseo\/v1\/notification\/blog-visibility-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/blog-visibility-reminder"}]}},"\/aioseo\/v1\/notification\/conflicting-plugins-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/conflicting-plugins-reminder"}]}},"\/aioseo\/v1\/notification\/description-format-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/description-format-reminder"}]}},"\/aioseo\/v1\/notification\/install-addons-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/install-addons-reminder"}]}},"\/aioseo\/v1\/notification\/install-aioseo-image-seo-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/install-aioseo-image-seo-reminder"}]}},"\/aioseo\/v1\/notification\/install-aioseo-local-business-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/install-aioseo-local-business-reminder"}]}},"\/aioseo\/v1\/notification\/install-aioseo-news-sitemap-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/install-aioseo-news-sitemap-reminder"}]}},"\/aioseo\/v1\/notification\/install-aioseo-video-sitemap-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/install-aioseo-video-sitemap-reminder"}]}},"\/aioseo\/v1\/notification\/install-mi-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/install-mi-reminder"}]}},"\/aioseo\/v1\/notification\/install-om-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/install-om-reminder"}]}},"\/aioseo\/v1\/notification\/v3-migration-custom-field-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/v3-migration-custom-field-reminder"}]}},"\/aioseo\/v1\/notification\/v3-migration-schema-number-reminder":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notification\/v3-migration-schema-number-reminder"}]}},"\/aioseo\/v1\/notifications\/dismiss":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/notifications\/dismiss"}]}},"\/aioseo\/v1\/objects":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/objects"}]}},"\/aioseo\/v1\/plugins\/deactivate":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/plugins\/deactivate"}]}},"\/aioseo\/v1\/plugins\/install":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/plugins\/install"}]}},"\/aioseo\/v1\/plugins\/upgrade":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/plugins\/upgrade"}]}},"\/aioseo\/v1\/reset-settings":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/reset-settings"}]}},"\/aioseo\/v1\/search-statistics\/sitemap\/delete":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/search-statistics\/sitemap\/delete"}]}},"\/aioseo\/v1\/search-statistics\/sitemap\/ignore":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/search-statistics\/sitemap\/ignore"}]}},"\/aioseo\/v1\/settings\/export":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/export"}]}},"\/aioseo\/v1\/settings\/export-content":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/export-content"}]}},"\/aioseo\/v1\/settings\/hide-setup-wizard":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/hide-setup-wizard"}]}},"\/aioseo\/v1\/settings\/hide-upgrade-bar":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/hide-upgrade-bar"}]}},"\/aioseo\/v1\/settings\/import":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/import"}]}},"\/aioseo\/v1\/settings\/import\/(?P<siteId>[\\d]+)":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/settings\/import-plugins":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/import-plugins"}]}},"\/aioseo\/v1\/settings\/toggle-card":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/toggle-card"}]}},"\/aioseo\/v1\/settings\/toggle-radio":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/toggle-radio"}]}},"\/aioseo\/v1\/settings\/dismiss-alert":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/dismiss-alert"}]}},"\/aioseo\/v1\/settings\/dismiss-review-cta":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/dismiss-review-cta"}]}},"\/aioseo\/v1\/settings\/items-per-page":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/items-per-page"}]}},"\/aioseo\/v1\/settings\/semrush-country":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/semrush-country"}]}},"\/aioseo\/v1\/settings\/do-task":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/settings\/do-task"}]}},"\/aioseo\/v1\/sitemap\/deactivate-conflicting-plugins":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/sitemap\/deactivate-conflicting-plugins"}]}},"\/aioseo\/v1\/sitemap\/delete-static-files":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/sitemap\/delete-static-files"}]}},"\/aioseo\/v1\/sitemap\/validate-html-sitemap-slug":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/sitemap\/validate-html-sitemap-slug"}]}},"\/aioseo\/v1\/tools\/delete-robots-txt":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/tools\/delete-robots-txt"}]}},"\/aioseo\/v1\/tools\/import-robots-txt":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/tools\/import-robots-txt"}]}},"\/aioseo\/v1\/spell-checker\/download-dictionary":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/spell-checker\/download-dictionary"}]}},"\/aioseo\/v1\/spell-checker\/safe-words\/add":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/spell-checker\/safe-words\/add"}]}},"\/aioseo\/v1\/spell-checker\/safe-words\/remove":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/spell-checker\/safe-words\/remove"}]}},"\/aioseo\/v1\/spell-checker\/safe-words\/match-case":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/spell-checker\/safe-words\/match-case"}]}},"\/aioseo\/v1\/wizard":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/wizard"}]}},"\/aioseo\/v1\/integration\/semrush\/authenticate":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/integration\/semrush\/authenticate"}]}},"\/aioseo\/v1\/integration\/semrush\/refresh":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/integration\/semrush\/refresh"}]}},"\/aioseo\/v1\/integration\/semrush\/keyphrases":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/integration\/semrush\/keyphrases"}]}},"\/aioseo\/v1\/integration\/wpcode\/snippets":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/integration\/wpcode\/snippets"}]}},"\/aioseo\/v1\/crawl-cleanup":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/crawl-cleanup"}]}},"\/aioseo\/v1\/crawl-cleanup\/block":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/crawl-cleanup\/block"}]}},"\/aioseo\/v1\/crawl-cleanup\/delete-blocked":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/crawl-cleanup\/delete-blocked"}]}},"\/aioseo\/v1\/crawl-cleanup\/delete-unblocked":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/crawl-cleanup\/delete-unblocked"}]}},"\/aioseo\/v1\/email-summary\/send":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/email-summary\/send"}]}},"\/aioseo\/v1\/writing-assistant\/process":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/writing-assistant\/process"}]}},"\/aioseo\/v1\/writing-assistant\/content-analysis":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/writing-assistant\/content-analysis"}]}},"\/aioseo\/v1\/writing-assistant\/disconnect":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/writing-assistant\/disconnect"}]}},"\/aioseo\/v1\/writing-assistant\/set-report-progress":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/writing-assistant\/set-report-progress"}]}},"\/aioseo\/v1\/ai\/insights\/reports\/(?P<uuid>[a-zA-Z0-9-]+)\/process":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/ai\/insights\/reports\/(?P<uuid>[a-zA-Z0-9-]+)\/regenerate":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/ai\/insights\/brand-tracker\/subscribe":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai\/insights\/brand-tracker\/subscribe"}]}},"\/aioseo\/v1\/truseo\/posts\/(?P<postId>[\\d]+)":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/truseo\/terms\/(?P<termId>[\\d]+)":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/aioseo\/v1\/seo-checklist\/complete":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist\/complete"}]}},"\/aioseo\/v1\/seo-checklist\/uncomplete":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist\/uncomplete"}]}},"\/aioseo\/v1\/seo-checklist\/bulk-complete":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist\/bulk-complete"}]}},"\/aioseo\/v1\/seo-checklist\/bulk-uncomplete":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist\/bulk-uncomplete"}]}},"\/aioseo\/v1\/seo-checklist\/action":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist\/action"}]}},"\/aioseo\/v1\/seo-checklist\/fetch":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/seo-checklist\/fetch"}]}},"\/aioseo\/v1\/ai-agents\/install-mcp-adapter":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai-agents\/install-mcp-adapter"}]}},"\/aioseo\/v1\/ai-agents\/generate-app-password":{"namespace":"aioseo\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/ai-agents\/generate-app-password"}]}},"\/aioseo\/v1\/search-statistics\/auth":{"namespace":"aioseo\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/aioseo\/v1\/search-statistics\/auth"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4"}]}},"\/jetpack\/v4\/backup-helper-script":{"namespace":"jetpack\/v4","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"helper":{"description":"Corpo dello script dell'helper del backup con codifica base64.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"path":{"description":"Percorso per lo script dell'helper del backup","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/backup-helper-script"}]}},"\/jetpack\/v4\/database-object\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"object_type":{"description":"Tipo di oggetto da recuperare dal database","required":true},"object_id":{"description":"ID dell'oggetto del database da recuperare","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/database-object\/backup"}]}},"\/jetpack\/v4\/options\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Uno o pi\u00f9 nomi di opzioni da includere nel backup","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/options\/backup"}]}},"\/jetpack\/v4\/comments\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/posts\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/terms\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/users\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/site\/backup\/undo-event":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/backup\/undo-event"}]}},"\/jetpack\/v4\/orders\/(?P<id>\\d+)\/backup":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/site\/backup\/preflight":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/backup\/preflight"}]}},"\/jetpack\/v4\/jetpack-ai-jwt":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/jetpack-ai-jwt"}]}},"\/jetpack\/v4\/plans":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/plans"}]}},"\/jetpack\/v4\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/products"}]}},"\/jetpack\/v4\/marketing\/survey":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/marketing\/survey"}]}},"\/jetpack\/v4\/rewind":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/rewind"}]}},"\/jetpack\/v4\/scan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/scan"}]}},"\/jetpack\/v4\/connection\/url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"from":{"type":"string","required":false},"redirect":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/url"}]}},"\/jetpack\/v4\/tracking\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"tracks_opt_out":{"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/tracking\/settings"}]}},"\/jetpack\/v4\/site":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site"}]}},"\/jetpack\/v4\/site\/features":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/features"}]}},"\/jetpack\/v4\/site\/products":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/products"}]}},"\/jetpack\/v4\/site\/purchases":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/purchases"}]}},"\/jetpack\/v4\/site\/benefits":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/benefits"}]}},"\/jetpack\/v4\/site\/activity":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/activity"}]}},"\/jetpack\/v4\/module\/all":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/module\/all"}]}},"\/jetpack\/v4\/module\/all\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"default":"","type":"array","items":{"type":"string"},"required":true},"active":{"default":true,"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/module\/all\/active"}]}},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Blocchi Jetpack disattivati.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Schema colori.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Se disponibili, mostra i metadati della foto (<a href=\"https:\/\/en.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) nel carosello.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Mostra l&#039;area dei commenti nel carosello","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Scrivi un Saluto","type":"string","default":"Rispondi","required":false},"jetpack_comment_form_color_scheme":{"description":"Schema di colori","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"jetpack_portfolio":{"description":"Abilita o disabilita il tipo di contenuto &quot;portfolio&quot; di Jetpack.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"Numero di entrate da mostrare nelle pagine del Portfolio.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Abilita o disabilita il post type testimonial di Jetpack.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"Numero di entrate da mostrare nelle pagine Testimonianze.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Abilita regole automatiche: proteggi il tuo sito da fonti di traffico non attendibili con regole di sicurezza automatiche","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Elenco Blocca - blocca un IP di richiesta specifico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Indirizzo IP bloccato","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Elenco Consenti - consenti un IP di richiesta specifico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"Indirizzi IP sempre consentiti","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Condividi i dati essenziali con Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Condividi i dati dettagliati con Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Mostra tutte le immagini della galleria in un fantastico mosaico.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Visualizza i profili quando il cursore passa sui loro Gravatar","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Verso l&#039;infinito e oltre","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Utilizza Google Analytics con lo Scorrimento Infinito","type":"boolean","default":0,"required":false},"wpl_default":{"description":"I Mi piace su WordPress.com sono","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Invia una notifica email quando qualcuno fa like a un post","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Usa Markdown per i commenti.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Usa il Markdown per i post","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Ricevi le notifiche via email dal modulo Monitor","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"Indirizzo email","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Proteggi la chiave API","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Proteggi l&#039;elenco consentito di indirizzi IP globali","type":"string","default":"","required":false},"sharing_services":{"description":"Servizi attivi e quelli nascosti dietro un pulsante","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Stile del pulsante","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"Etichetta di condivisione","type":"string","default":"","required":false},"show":{"description":"Mostra dove sono visualizzati i pulsanti","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"Il nome utente su Twitter del proprietario del dominio di questo sito.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Disabilita CSS e JS","type":"boolean","default":0,"required":false},"custom":{"description":"Servizi di condivisione personalizzati sono stati aggiunti dall&#039;utente.","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Elimina il servizio personalizzato di condivisione.","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"Richiede Autenticazione a 2 fattori (Two-Step)","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Confronto con Mail","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Mostra un&#039;opzione &lt;em&gt;&#039;segui il blog&#039;&lt;\/em&gt; nel modulo per i commenti","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Mostra un&#039;opzione &lt;em&gt;&#039;segui i commenti&#039;&lt;\/em&gt; nel modulo per i commenti","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Matrice degli ID delle categorie articolo contrassegnati come categorie della newsletter","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Se le categorie della newsletter sono abilitate o meno","type":"boolean","default":0,"required":false},"wpcom_newsletter_send_default":{"description":"Se inviare e-mail della newsletter per impostazione predefinita durante la pubblicazione di un articolo","type":"boolean","default":1,"required":false},"wpcom_featured_image_in_email":{"description":"Se includere o meno l&#039;immagine in evidenza nell&#039;e-mail","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Se mostrare l&#039;autore dell&#039;avatar nella byline dell&#039;e-mail","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Se mostrare il nome dell&#039;autore nella byline dell&#039;e-mail","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Se mostrare la data nella byline dell&#039;e-mail","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Se usare o meno l&#039;estratto nell&#039;e-mail","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Comportamento di risposta alle e-mail per le e-mail di newsletter","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Nome mittente per le e-mail della newsletter","type":"string","default":"","required":false},"sm_enabled":{"description":"Mostra un popup di abbonamento modale ai lettori.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Mostra sovrapposizione di abbonamento sulla homepage.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Mostra un pulsante mobile di abbonamento.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"Aggiungi il blocco Abbonati alla fine di ogni articolo.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"Aggiungi il blocco Accesso abbonati alla navigazione.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"Aggiungi blocco Abbonati alla navigazione.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"Invia una notifica via e-mail quando qualcuno si iscrive al mio blog","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Opzioni utilizzate nei modelli delle email di iscrizione e nel blocco Iscriviti: &#039;invitation&#039;, &#039;welcome&#039;, &#039;comment_follow&#039;, &#039;subscribe_modal_heading&#039;, &#039;free_tier_description&#039; e &#039;hide_free_tier&#039;.","type":"object","default":{"invitation":"","welcome":"","comment_follow":"","subscribe_modal_heading":"","free_tier_description":"","hide_free_tier":false},"required":false},"show_headline":{"description":"Evidenzia il contenuto correlato con un&#039;intestazione","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Visualizza un&#039;immagine in miniatura se disponibile","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Abilita ricerca istantanea","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Ha un acquisto del prodotto Jetpack Search attivo","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"Attiva una configurazione automatica della ricerca istantanea","type":"boolean","default":0,"required":false},"google":{"description":"Google Search Console","type":"string","default":"","required":false},"bing":{"description":"Centro Webmaster Bing","type":"string","default":"","required":false},"pinterest":{"description":"Verifica del sito da Pinterest","type":"string","default":"","required":false},"yandex":{"description":"Verifica sito con Yandex ","type":"string","default":"","required":false},"facebook":{"description":"Verifica del dominio di Facebook","type":"string","default":"","required":false},"enable_header_ad":{"description":"Mostra una pubblicit\u00e0 all&#039;inizio di ogni pagina. ","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"Questo sito \u00e8 stato approvato per WordAds?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"Visualizzare una seconda pubblicit\u00e0 sotto gli articoli?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"Mostrare l&#039;annuncio pubblicitario in linea all&#039;interno del contenuto dell&#039;articolo?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"Visualizzare pubblicit\u00e0 sulla pagina principale?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"Visualizzare pubblicit\u00e0 sugli articoli?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"Visualizzare pubblicit\u00e0 sulle pagine?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"Visualizzare pubblicit\u00e0 o pagine di archivio?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":" ads.txt personalizzato","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Personalizza le voci di ads.txt","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Abilita il supporto per il California Consumer Privacy Act","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL dell&#039;informativa sulla privacy","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Abilita il banner di gestione del consenso GDPR per WordAds","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"Includi un piccolo grafico nella barra di amministrazione con istantanee di 48 ore di traffico.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Anteprima della nuova esperienza Jetpack Stats (sperimentale).","type":"boolean","default":1,"required":false},"roles":{"description":"Seleziona i ruoli che potranno visualizzare i prospetti statistici.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Conta le visualizzazioni di pagina degli utenti registrati collegati.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"ID del Blog.","type":"boolean","default":0,"required":false},"do_not_track":{"description":"Non tracciare.","type":"boolean","default":1,"required":false},"version":{"description":"Versione.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Comprimi i suggerimenti per l&#039;aggiornamento","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Mostra le visualizzazioni degli articoli nel Reader di WordPress.com.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Lingua primaria per il sito.","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Descrizione metadati pagina iniziale.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"Strutture titolo pagina SEO.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"jetpack_seo_llms_txt_enabled":{"description":"Crea un file llms.txt per guidare gli assistenti IA nella navigazione dei tuoi contenuti.","type":"boolean","default":0,"required":false},"jetpack_seo_ai_crawler_overrides":{"description":"Impostazioni di autorizzazione\/blocco per i crawler basati sull&#039;IA.","type":"object","default":[],"required":false},"videopress_private_enabled_for_site":{"description":"Privacy del video: Limita le visite ai membri di questo sito","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Genera automaticamente titolo SEO, descrizione SEO e testo alternativo dell&#039;immagine per i nuovi articoli.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"podcast":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/active":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"active":{"default":true,"type":"boolean","required":true}}}]},"\/jetpack\/v4\/module\/(?P<slug>[a-z\\-]+)\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"range":{"default":"day","type":"string","required":false}}}]},"\/jetpack\/v4\/module\/(?P<service>[a-z\\-]+)\/key\/check":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"api_key":{"default":"","type":"string","required":false}}}]},"\/jetpack\/v4\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false},"jetpack_blocks_disabled":{"description":"Blocchi Jetpack disattivati.","type":"boolean","default":false,"required":false},"carousel_background_color":{"description":"Schema colori.","type":"string","default":"black","enum":["black","white"],"required":false},"carousel_display_exif":{"description":"Se disponibili, mostra i metadati della foto (<a href=\"https:\/\/en.wikipedia.org\/wiki\/Exchangeable_image_file_format\" target=\"_blank\">Exif<\/a>) nel carosello.","type":"boolean","default":0,"required":false},"carousel_display_comments":{"description":"Mostra l&#039;area dei commenti nel carosello","type":"boolean","default":1,"required":false},"highlander_comment_form_prompt":{"description":"Scrivi un Saluto","type":"string","default":"Rispondi","required":false},"jetpack_comment_form_color_scheme":{"description":"Schema di colori","type":"string","default":"light","enum":["light","dark","transparent"],"required":false},"jetpack_portfolio":{"description":"Abilita o disabilita il tipo di contenuto &quot;portfolio&quot; di Jetpack.","type":"boolean","default":0,"required":false},"jetpack_portfolio_posts_per_page":{"description":"Numero di entrate da mostrare nelle pagine del Portfolio.","type":"integer","default":10,"required":false},"jetpack_testimonial":{"description":"Abilita o disabilita il post type testimonial di Jetpack.","type":"boolean","default":0,"required":false},"jetpack_testimonial_posts_per_page":{"description":"Numero di entrate da mostrare nelle pagine Testimonianze.","type":"integer","default":10,"required":false},"jetpack_waf_automatic_rules":{"description":"Abilita regole automatiche: proteggi il tuo sito da fonti di traffico non attendibili con regole di sicurezza automatiche","type":"boolean","default":false,"required":false},"jetpack_waf_ip_block_list_enabled":{"description":"Elenco Blocca - blocca un IP di richiesta specifico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_block_list":{"description":"Indirizzo IP bloccato","type":"string","default":"","required":false},"jetpack_waf_ip_allow_list_enabled":{"description":"Elenco Consenti - consenti un IP di richiesta specifico.","type":"boolean","default":0,"required":false},"jetpack_waf_ip_allow_list":{"description":"Indirizzi IP sempre consentiti","type":"string","default":"","required":false},"jetpack_waf_share_data":{"description":"Condividi i dati essenziali con Jetpack.","type":"boolean","default":0,"required":false},"jetpack_waf_share_debug_data":{"description":"Condividi i dati dettagliati con Jetpack.","type":"boolean","default":0,"required":false},"tiled_galleries":{"description":"Mostra tutte le immagini della galleria in un fantastico mosaico.","type":"boolean","default":0,"required":false},"gravatar_disable_hovercards":{"description":"Visualizza i profili quando il cursore passa sui loro Gravatar","type":"string","default":"enabled","enum":["enabled","disabled"],"required":false},"infinite_scroll":{"description":"Verso l&#039;infinito e oltre","type":"boolean","default":1,"required":false},"infinite_scroll_google_analytics":{"description":"Utilizza Google Analytics con lo Scorrimento Infinito","type":"boolean","default":0,"required":false},"wpl_default":{"description":"I Mi piace su WordPress.com sono","type":"string","default":"on","enum":["on","off"],"required":false},"social_notifications_like":{"description":"Invia una notifica email quando qualcuno fa like a un post","type":"boolean","default":1,"required":false},"wpcom_publish_comments_with_markdown":{"description":"Usa Markdown per i commenti.","type":"boolean","default":0,"required":false},"wpcom_publish_posts_with_markdown":{"description":"Usa il Markdown per i post","type":"boolean","default":0,"required":false},"monitor_receive_notifications":{"description":"Ricevi le notifiche via email dal modulo Monitor","type":"boolean","default":0,"required":false},"post_by_email_address":{"description":"Indirizzo email","type":"string","default":"noop","enum":["noop","create","regenerate","delete"],"required":false},"jetpack_protect_key":{"description":"Proteggi la chiave API","type":"string","default":"","required":false},"jetpack_protect_global_whitelist":{"description":"Proteggi l&#039;elenco consentito di indirizzi IP globali","type":"string","default":"","required":false},"sharing_services":{"description":"Servizi attivi e quelli nascosti dietro un pulsante","type":"object","default":{"visible":["facebook","x"],"hidden":[]},"required":false},"button_style":{"description":"Stile del pulsante","type":"string","default":"icon","enum":["icon-text","icon","text","official"],"required":false},"sharing_label":{"description":"Etichetta di condivisione","type":"string","default":"","required":false},"show":{"description":"Mostra dove sono visualizzati i pulsanti","type":"array","items":{"type":"string"},"default":["post"],"required":false},"jetpack-twitter-cards-site-tag":{"description":"Il nome utente su Twitter del proprietario del dominio di questo sito.","type":"string","default":"","required":false},"sharedaddy_disable_resources":{"description":"Disabilita CSS e JS","type":"boolean","default":0,"required":false},"custom":{"description":"Servizi di condivisione personalizzati sono stati aggiunti dall&#039;utente.","type":"object","default":{"sharing_name":"","sharing_url":"","sharing_icon":""},"required":false},"sharing_delete_service":{"description":"Elimina il servizio personalizzato di condivisione.","type":"string","default":"","required":false},"jetpack_sso_require_two_step":{"description":"Richiede Autenticazione a 2 fattori (Two-Step)","type":"boolean","default":false,"required":false},"jetpack_sso_match_by_email":{"description":"Confronto con Mail","type":"boolean","default":1,"required":false},"stb_enabled":{"description":"Mostra un&#039;opzione &lt;em&gt;&#039;segui il blog&#039;&lt;\/em&gt; nel modulo per i commenti","type":"boolean","default":1,"required":false},"stc_enabled":{"description":"Mostra un&#039;opzione &lt;em&gt;&#039;segui i commenti&#039;&lt;\/em&gt; nel modulo per i commenti","type":"boolean","default":1,"required":false},"wpcom_newsletter_categories":{"description":"Matrice degli ID delle categorie articolo contrassegnati come categorie della newsletter","type":"array","default":[],"required":false},"wpcom_newsletter_categories_enabled":{"description":"Se le categorie della newsletter sono abilitate o meno","type":"boolean","default":0,"required":false},"wpcom_newsletter_send_default":{"description":"Se inviare e-mail della newsletter per impostazione predefinita durante la pubblicazione di un articolo","type":"boolean","default":1,"required":false},"wpcom_featured_image_in_email":{"description":"Se includere o meno l&#039;immagine in evidenza nell&#039;e-mail","type":"boolean","default":0,"required":false},"jetpack_gravatar_in_email":{"description":"Se mostrare l&#039;autore dell&#039;avatar nella byline dell&#039;e-mail","type":"boolean","default":1,"required":false},"jetpack_author_in_email":{"description":"Se mostrare il nome dell&#039;autore nella byline dell&#039;e-mail","type":"boolean","default":1,"required":false},"jetpack_post_date_in_email":{"description":"Se mostrare la data nella byline dell&#039;e-mail","type":"boolean","default":1,"required":false},"wpcom_subscription_emails_use_excerpt":{"description":"Se usare o meno l&#039;estratto nell&#039;e-mail","type":"boolean","default":0,"required":false},"jetpack_subscriptions_reply_to":{"description":"Comportamento di risposta alle e-mail per le e-mail di newsletter","type":"string","default":"comment","required":false},"jetpack_subscriptions_from_name":{"description":"Nome mittente per le e-mail della newsletter","type":"string","default":"","required":false},"sm_enabled":{"description":"Mostra un popup di abbonamento modale ai lettori.","type":"boolean","default":0,"required":false},"jetpack_subscribe_overlay_enabled":{"description":"Mostra sovrapposizione di abbonamento sulla homepage.","type":"boolean","default":0,"required":false},"jetpack_subscribe_floating_button_enabled":{"description":"Mostra un pulsante mobile di abbonamento.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_post_end_enabled":{"description":"Aggiungi il blocco Abbonati alla fine di ogni articolo.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_login_navigation_enabled":{"description":"Aggiungi il blocco Accesso abbonati alla navigazione.","type":"boolean","default":0,"required":false},"jetpack_subscriptions_subscribe_navigation_enabled":{"description":"Aggiungi blocco Abbonati alla navigazione.","type":"boolean","default":0,"required":false},"social_notifications_subscribe":{"description":"Invia una notifica via e-mail quando qualcuno si iscrive al mio blog","type":"boolean","default":0,"required":false},"subscription_options":{"description":"Opzioni utilizzate nei modelli delle email di iscrizione e nel blocco Iscriviti: &#039;invitation&#039;, &#039;welcome&#039;, &#039;comment_follow&#039;, &#039;subscribe_modal_heading&#039;, &#039;free_tier_description&#039; e &#039;hide_free_tier&#039;.","type":"object","default":{"invitation":"","welcome":"","comment_follow":"","subscribe_modal_heading":"","free_tier_description":"","hide_free_tier":false},"required":false},"show_headline":{"description":"Evidenzia il contenuto correlato con un&#039;intestazione","type":"boolean","default":1,"required":false},"show_thumbnails":{"description":"Visualizza un&#039;immagine in miniatura se disponibile","type":"boolean","default":0,"required":false},"instant_search_enabled":{"description":"Abilita ricerca istantanea","type":"boolean","default":0,"required":false},"has_jetpack_search_product":{"description":"Ha un acquisto del prodotto Jetpack Search attivo","type":"boolean","default":0,"required":false},"search_auto_config":{"description":"Attiva una configurazione automatica della ricerca istantanea","type":"boolean","default":0,"required":false},"google":{"description":"Google Search Console","type":"string","default":"","required":false},"bing":{"description":"Centro Webmaster Bing","type":"string","default":"","required":false},"pinterest":{"description":"Verifica del sito da Pinterest","type":"string","default":"","required":false},"yandex":{"description":"Verifica sito con Yandex ","type":"string","default":"","required":false},"facebook":{"description":"Verifica del dominio di Facebook","type":"string","default":"","required":false},"enable_header_ad":{"description":"Mostra una pubblicit\u00e0 all&#039;inizio di ogni pagina. ","type":"boolean","default":1,"required":false},"wordads_approved":{"description":"Questo sito \u00e8 stato approvato per WordAds?","type":"boolean","default":0,"required":false},"wordads_second_belowpost":{"description":"Visualizzare una seconda pubblicit\u00e0 sotto gli articoli?","type":"boolean","default":1,"required":false},"wordads_inline_enabled":{"description":"Mostrare l&#039;annuncio pubblicitario in linea all&#039;interno del contenuto dell&#039;articolo?","type":"boolean","default":1,"required":false},"wordads_display_front_page":{"description":"Visualizzare pubblicit\u00e0 sulla pagina principale?","type":"boolean","default":1,"required":false},"wordads_display_post":{"description":"Visualizzare pubblicit\u00e0 sugli articoli?","type":"boolean","default":1,"required":false},"wordads_display_page":{"description":"Visualizzare pubblicit\u00e0 sulle pagine?","type":"boolean","default":1,"required":false},"wordads_display_archive":{"description":"Visualizzare pubblicit\u00e0 o pagine di archivio?","type":"boolean","default":1,"required":false},"wordads_custom_adstxt_enabled":{"description":" ads.txt personalizzato","type":"boolean","default":0,"required":false},"wordads_custom_adstxt":{"description":"Personalizza le voci di ads.txt","type":"string","default":"","required":false},"wordads_ccpa_enabled":{"description":"Abilita il supporto per il California Consumer Privacy Act","type":"boolean","default":0,"required":false},"wordads_ccpa_privacy_policy_url":{"description":"URL dell&#039;informativa sulla privacy","type":"string","default":"","required":false},"wordads_cmp_enabled":{"description":"Abilita il banner di gestione del consenso GDPR per WordAds","type":"boolean","default":0,"required":false},"google_analytics_tracking_id":{"description":"Google Analytics","type":"string","default":"","required":false},"jetpack_wga":{"description":"Google Analytics","type":"object","required":false},"admin_bar":{"description":"Includi un piccolo grafico nella barra di amministrazione con istantanee di 48 ore di traffico.","type":"boolean","default":1,"required":false},"enable_odyssey_stats":{"description":"Anteprima della nuova esperienza Jetpack Stats (sperimentale).","type":"boolean","default":1,"required":false},"roles":{"description":"Seleziona i ruoli che potranno visualizzare i prospetti statistici.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"count_roles":{"description":"Conta le visualizzazioni di pagina degli utenti registrati collegati.","type":"array","items":{"type":"string"},"default":["administrator"],"required":false},"blog_id":{"description":"ID del Blog.","type":"boolean","default":0,"required":false},"do_not_track":{"description":"Non tracciare.","type":"boolean","default":1,"required":false},"version":{"description":"Versione.","type":"integer","default":9,"required":false},"collapse_nudges":{"description":"Comprimi i suggerimenti per l&#039;aggiornamento","type":"boolean","default":0,"required":false},"wpcom_reader_views_enabled":{"description":"Mostra le visualizzazioni degli articoli nel Reader di WordPress.com.","type":"boolean","default":1,"required":false},"akismet_show_user_comments_approved":{"description":"","type":"boolean","default":0,"required":false},"wordpress_api_key":{"description":"","type":"string","default":"","required":false},"dismiss_empty_stats_card":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_backup_getting_started":{"description":"","type":"boolean","default":0,"required":false},"dismiss_dash_agencies_learn_more":{"description":"","type":"boolean","default":0,"required":false},"lang_id":{"description":"Lingua primaria per il sito.","type":"string","default":"en_US","required":false},"advanced_seo_front_page_description":{"description":"Descrizione metadati pagina iniziale.","type":"string","default":"","required":false},"advanced_seo_title_formats":{"description":"Strutture titolo pagina SEO.","type":"object","default":{"archives":[],"front_page":[],"groups":[],"pages":[],"posts":[]},"required":false},"jetpack_seo_llms_txt_enabled":{"description":"Crea un file llms.txt per guidare gli assistenti IA nella navigazione dei tuoi contenuti.","type":"boolean","default":0,"required":false},"jetpack_seo_ai_crawler_overrides":{"description":"Impostazioni di autorizzazione\/blocco per i crawler basati sull&#039;IA.","type":"object","default":[],"required":false},"videopress_private_enabled_for_site":{"description":"Privacy del video: Limita le visite ai membri di questo sito","type":"boolean","default":0,"required":false},"ai_seo_enhancer_enabled":{"description":"Genera automaticamente titolo SEO, descrizione SEO e testo alternativo dell&#039;immagine per i nuovi articoli.","type":"boolean","default":0,"required":false},"account-protection":{"description":"","type":"boolean","default":0,"required":false},"blaze":{"description":"","type":"boolean","default":0,"required":false},"blocks":{"description":"","type":"boolean","default":0,"required":false},"canonical-urls":{"description":"","type":"boolean","default":0,"required":false},"carousel":{"description":"","type":"boolean","default":0,"required":false},"comment-likes":{"description":"","type":"boolean","default":0,"required":false},"comments":{"description":"","type":"boolean","default":0,"required":false},"contact-form":{"description":"","type":"boolean","default":0,"required":false},"copy-post":{"description":"","type":"boolean","default":0,"required":false},"custom-content-types":{"description":"","type":"boolean","default":0,"required":false},"google-fonts":{"description":"","type":"boolean","default":0,"required":false},"gravatar-hovercards":{"description":"","type":"boolean","default":0,"required":false},"infinite-scroll":{"description":"","type":"boolean","default":0,"required":false},"json-api":{"description":"","type":"boolean","default":0,"required":false},"latex":{"description":"","type":"boolean","default":0,"required":false},"likes":{"description":"","type":"boolean","default":0,"required":false},"markdown":{"description":"","type":"boolean","default":0,"required":false},"monitor":{"description":"","type":"boolean","default":0,"required":false},"notes":{"description":"","type":"boolean","default":0,"required":false},"photon-cdn":{"description":"","type":"boolean","default":0,"required":false},"photon":{"description":"","type":"boolean","default":0,"required":false},"podcast":{"description":"","type":"boolean","default":0,"required":false},"post-by-email":{"description":"","type":"boolean","default":0,"required":false},"post-list":{"description":"","type":"boolean","default":0,"required":false},"protect":{"description":"","type":"boolean","default":0,"required":false},"publicize":{"description":"","type":"boolean","default":0,"required":false},"related-posts":{"description":"","type":"boolean","default":0,"required":false},"search":{"description":"","type":"boolean","default":0,"required":false},"seo-tools":{"description":"","type":"boolean","default":0,"required":false},"sharedaddy":{"description":"","type":"boolean","default":0,"required":false},"shortcodes":{"description":"","type":"boolean","default":0,"required":false},"shortlinks":{"description":"","type":"boolean","default":0,"required":false},"sso":{"description":"","type":"boolean","default":0,"required":false},"stats":{"description":"","type":"boolean","default":0,"required":false},"subscriptions":{"description":"","type":"boolean","default":0,"required":false},"tiled-gallery":{"description":"","type":"boolean","default":0,"required":false},"vaultpress":{"description":"","type":"boolean","default":0,"required":false},"verification-tools":{"description":"","type":"boolean","default":0,"required":false},"videopress":{"description":"","type":"boolean","default":0,"required":false},"waf":{"description":"","type":"boolean","default":0,"required":false},"widget-visibility":{"description":"","type":"boolean","default":0,"required":false},"widgets":{"description":"","type":"boolean","default":0,"required":false},"woocommerce-analytics":{"description":"","type":"boolean","default":0,"required":false},"wordads":{"description":"","type":"boolean","default":0,"required":false},"wpcom-reader":{"description":"","type":"boolean","default":0,"required":false}}},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/settings"}]}},"\/jetpack\/v4\/settings\/(?P<slug>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"context":{"default":"edit","required":false}}}]},"\/jetpack\/v4\/options\/(?P<options>[a-z\\-]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/updates\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/updates\/plugins"}]}},"\/jetpack\/v4\/notice\/(?P<notice>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/plugins":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Abbreviazione della directory dei plugin di WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Lo stato di attivazione del plugin.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"source":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/plugins"}]}},"\/jetpack\/v4\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"type":"string","required":true},"source":{"type":"string","required":false}}}]},"\/jetpack\/v4\/plugin\/(?P<plugin>[a-z\\\/\\.\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/widgets\/(?P<id>[0-9a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"keyring_id":{"type":"integer","required":true}}}]},"\/jetpack\/v4\/verify-site\/(?P<service>[a-z\\-_]+)\/(?<keyring_id>[0-9]+)":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/recommendations\/data":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/recommendations\/data"}]}},"\/jetpack\/v4\/recommendations\/step":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"step":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/recommendations\/step"}]}},"\/jetpack\/v4\/recommendations\/product-suggestions":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/recommendations\/product-suggestions"}]}},"\/jetpack\/v4\/recommendations\/upsell":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/recommendations\/upsell"}]}},"\/jetpack\/v4\/recommendations\/conditional":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/recommendations\/conditional"}]}},"\/jetpack\/v4\/site\/discount":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/site\/discount"}]}},"\/jetpack\/v4\/jetpack_crm":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"extension":{"type":"text","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/jetpack_crm"}]}},"\/jetpack\/v4\/purchase-token":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/purchase-token"}]}},"\/jetpack\/v4\/seen-wc-connection-modal":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/seen-wc-connection-modal"}]}},"\/jetpack\/v4\/intro-offers":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/intro-offers"}]}},"\/jetpack\/v4\/subscribers\/auth":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_url":{"description":"L'URL a cui reindirizzare.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/subscribers\/auth"}]}},"\/jetpack\/v4\/features\/available":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/features\/available"}]}},"\/jetpack\/v4\/features\/enabled":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/features\/enabled"}]}},"\/jetpack\/v4\/licensing\/error":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"error":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/licensing\/error"}]}},"\/jetpack\/v4\/licensing\/set-license":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"license":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/licensing\/set-license"}]}},"\/jetpack\/v4\/licensing\/user\/licenses":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/licensing\/user\/licenses"}]}},"\/jetpack\/v4\/licensing\/user\/counts":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/licensing\/user\/counts"}]}},"\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"last_detached_count":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/licensing\/user\/activation-notice-dismiss"}]}},"\/jetpack\/v4\/licensing\/attach-licenses":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"licenses":{"type":"array","items":{"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/licensing\/attach-licenses"}]}},"\/jetpack\/v4\/heartbeat\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prefix":{"description":"Prefisso da aggiungere prima degli identificatori delle statistiche.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/heartbeat\/data"}]}},"\/jetpack\/v4\/verify_xmlrpc_error":{"namespace":"jetpack\/v4","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nonce":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/verify_xmlrpc_error"}]}},"\/jetpack\/v4\/sync\/full-sync":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"modules":{"description":"Moduli dei dati che dovrebbero essere inclusi nella sincronizzazione completa","type":"array","required":false},"users":{"description":"ID degli utenti da includere nella sincronizzazione completa o \"iniziale\"","required":false},"posts":{"description":"ID degli articoli da includere nella sincronizzazione completa","type":"array","required":false},"comments":{"description":"ID dei commenti da includere nella sincronizzazione completa","type":"array","required":false},"context":{"description":"Contesto per la sincronizzazione completa","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/full-sync"}]}},"\/jetpack\/v4\/sync\/status":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"fields":{"description":"Comma-separated list of additional fields that should be included in status.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/status"}]}},"\/jetpack\/v4\/sync\/health":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"status":{"description":"Nuovo stato di integrit\u00e0 della sincronizzazione","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/health"}]}},"\/jetpack\/v4\/sync\/settings":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/settings"}]}},"\/jetpack\/v4\/sync\/object":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"module_name":{"description":"Nome del modulo di sincronizzazione","type":"string","required":false},"object_type":{"description":"Tipo di oggetto","type":"string","required":false},"object_ids":{"description":"Identificatori degli oggetti","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/object"}]}},"\/jetpack\/v4\/sync\/now":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nome della coda di sincronizzazione.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/now"}]}},"\/jetpack\/v4\/sync\/checkout":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nome della coda di sincronizzazione.","type":"string","required":false},"number_of_items":{"description":"Numero di elementi da pagare dalla coda.","type":"integer","required":false},"pop":{"description":"Sposta gli elementi dalla coda invece di effettuare il pagamento.","type":"boolean","required":false},"force":{"description":"Forza lo sblocco della coda prima del pagamento.","type":"boolean","required":false},"encode":{"description":"Codifica gli elementi prima dell'invio.","type":"boolean","default":true,"required":false},"use_memory_limit":{"description":"Usa il pagamento basato sulla memoria invece del conteggio degli elementi fisso.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/checkout"}]}},"\/jetpack\/v4\/sync\/close":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/close"}]}},"\/jetpack\/v4\/sync\/unlock":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"queue":{"description":"Nome della coda di sincronizzazione.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/unlock"}]}},"\/jetpack\/v4\/sync\/object-id-range":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"sync_module":{"description":"Nome del modulo di sincronizzazione.","type":"string","required":true},"batch_size":{"description":"Dimensione dei batch","type":"int","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/object-id-range"}]}},"\/jetpack\/v4\/sync\/data-check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"perform_text_conversion":{"description":"Se i campi di testo devono essere convertiti in latin1 nel calcolo del checksum.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/data-check"}]}},"\/jetpack\/v4\/sync\/data-histogram":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"columns":{"description":"Mappature colonna","type":"array","required":false},"object_type":{"description":"Tipo di oggetto","type":"string","required":false},"buckets":{"description":"Numero di bucket dell'istogramma.","type":"int","required":false},"start_id":{"description":"ID di inizio per l'istogramma","type":"int","required":false},"end_id":{"description":"ID di fine per l'istogramma","type":"int","required":false},"strip_non_ascii":{"description":"Rimuovere i caratteri non ascii?","type":"boolean","required":false},"shared_salt":{"description":"Salt condiviso da usare durante la generazione del checksum","type":"string","required":false},"only_range_edges":{"description":"Should only range edges be returned","type":"boolean","required":false},"detailed_drilldown":{"description":"Vogliamo il checksum o gli ID dell'oggetto.","type":"boolean","required":false},"perform_text_conversion":{"description":"Se i campi di testo devono essere convertiti in latin1 nel calcolo del checksum.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/data-histogram"}]}},"\/jetpack\/v4\/sync\/spawn-sync":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/spawn-sync"}]}},"\/jetpack\/v4\/sync\/locks":{"namespace":"jetpack\/v4","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/locks"}]}},"\/jetpack\/v4\/sync\/clear-queue":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/sync\/clear-queue"}]}},"\/jetpack\/v4\/jitm":{"namespace":"jetpack\/v4","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/jitm"}]}},"\/jetpack\/v4\/identity-crisis\/confirm-safe-mode":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/identity-crisis\/confirm-safe-mode"}]}},"\/jetpack\/v4\/identity-crisis\/migrate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/identity-crisis\/migrate"}]}},"\/jetpack\/v4\/identity-crisis\/start-fresh":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"redirect_uri":{"description":"URI della pagina di amministrazione a cui l'utente dovrebbe essere rendirizzato dopo il flusso di connessione","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/identity-crisis\/start-fresh"}]}},"\/jetpack\/v4\/identity-crisis\/idc-url-validation":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/identity-crisis\/idc-url-validation"}]}},"\/jetpack\/v4\/identity-crisis\/url-secret":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/identity-crisis\/url-secret"}]}},"\/jetpack\/v4\/identity-crisis\/compare-url-secret":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"secret":{"description":"URL segreto da paragonare a quelli memorizzati nel database.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/identity-crisis\/compare-url-secret"}]}},"\/jetpack\/v4\/search\/plan":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search\/plan"}]}},"\/jetpack\/v4\/search\/settings":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search\/settings"}]}},"\/jetpack\/v4\/search\/stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search\/stats"}]}},"\/jetpack\/v4\/search\/pricing":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search\/pricing"}]}},"\/jetpack\/v4\/search\/templates\/(?P<post_type>[a-z0-9_-]+)":{"namespace":"jetpack\/v4","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"post_type":{"required":true}}}]},"\/jetpack\/v4\/search\/plan\/activate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search\/plan\/activate"}]}},"\/jetpack\/v4\/search\/plan\/deactivate":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search\/plan\/deactivate"}]}},"\/jetpack\/v4\/search":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search"}]}},"\/jetpack\/v4\/search\/local-stats":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/search\/local-stats"}]}},"\/jetpack\/v4\/waf":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/waf"}]}},"\/jetpack\/v4\/waf\/update-rules":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/waf\/update-rules"}]}},"\/jetpack\/v4\/stats-app":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/stats-app","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/(?P<resource>[\\-\\w]+)\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/posts\/(?P<resource_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/posts\/(?P<resource_id>[\\d]+)\/likes":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/stats"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/site-has-never-published-post":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/site-has-never-published-post"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/posts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/posts"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/subscribers\/counts":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/subscribers\/counts"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats\/usage":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats\/usage"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats\/user-feedback":{"namespace":"jetpack\/v4\/stats-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats\/user-feedback"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/wordads\/earnings":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/wordads\/earnings"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/wordads\/stats":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/wordads\/stats"}]}},"\/jetpack\/v4\/stats-app\/stats\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":null,"description":"Postponed for (in seconds)","minimum":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/stats\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats-dashboard\/notices":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"ID of the notice","required":true},"status":{"type":"string","description":"Status of the notice","required":true},"postponed_for":{"type":"number","default":null,"description":"Postponed for (in seconds)","minimum":0,"required":false}}},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats-dashboard\/notices"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/referrers\/spam":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/referrers\/spam"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/referrers\/spam\/new":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/referrers\/spam\/new"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/referrers\/spam\/delete":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"domain":{"type":"string","description":"Domain of the referrer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/referrers\/spam\/delete"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats-dashboard\/modules":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats-dashboard\/modules"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats-dashboard\/module-settings":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH","GET"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/jetpack-stats-dashboard\/module-settings"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/emails\/(?P<resource>[\\-\\w\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/opens\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/clicks\/emails\/(?P<post_id>[\\d]+)\/(?P<resource>[\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/(?P<resource>[\\-\\w]+)\/emails\/(?P<post_id>[\\d]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/utm\/(?P<utm_params>[_,\\-\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/devices\/(?P<device_property>[\\w]+)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/stats-app\/sites\/208001370\/commercial-classification":{"namespace":"jetpack\/v4\/stats-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/commercial-classification"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/purchases":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats-app\/sites\/208001370\/purchases"}]}},"\/jetpack\/v4\/stats-app\/sites\/208001370\/stats\/location-views\/(?P<geo_mode>country|region|city)":{"namespace":"jetpack\/v4\/stats-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/activity-log":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Numero di elementi da restituire per pagina.","type":"integer","minimum":1,"maximum":1000,"required":false},"page":{"description":"Numero di pagina (indice base 1).","type":"integer","minimum":1,"required":false},"sort_order":{"description":"Direzione dell'ordinamento.","type":"string","enum":["asc","desc"],"required":false},"after":{"description":"Limite inferiore ISO 8601 per la data e ora dell'evento.","type":"string","format":"date-time","required":false},"before":{"description":"Limite superiore ISO 8601 per la data e ora dell'evento.","type":"string","format":"date-time","required":false},"group":{"description":"Restituisci solo gli eventi appartenenti a questi gruppi.","type":"array","items":{"type":"string"},"required":false},"not_group":{"description":"Escludi gli eventi in questi gruppi.","type":"array","items":{"type":"string"},"required":false},"text_search":{"description":"Stringa di ricerca full-text.","type":"string","required":false},"actor":{"description":"Restituisce solo gli eventi eseguiti da questi ID attore.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/activity-log"}]}},"\/jetpack\/v4\/activity-log\/count\/group":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Limite massimo di eventi considerati durante il conteggio dei gruppi.","type":"integer","minimum":1,"maximum":1000,"required":false},"after":{"description":"Limite inferiore ISO 8601 per la data e ora dell'evento.","type":"string","format":"date-time","required":false},"before":{"description":"Limite superiore ISO 8601 per la data e ora dell'evento.","type":"string","format":"date-time","required":false},"group":{"description":"Conta solo gli eventi appartenenti a questi gruppi.","type":"array","items":{"type":"string"},"required":false},"not_group":{"description":"Escludi gli eventi in questi gruppi.","type":"array","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/activity-log\/count\/group"}]}},"\/jetpack\/v4\/activity-log\/actors":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Limita il numero di eventi considerati durante la raccolta degli attori.","type":"integer","minimum":1,"maximum":1000,"required":false},"after":{"description":"Limite inferiore ISO 8601 per la data e ora dell'evento.","type":"string","format":"date-time","required":false},"before":{"description":"Limite superiore ISO 8601 per la data e ora dell'evento.","type":"string","format":"date-time","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/activity-log\/actors"}]}},"\/jetpack\/v4\/blaze-app":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/blaze-app","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze-app"}]}},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/blaze\/posts(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze-app\/sites\/208001370\/blaze\/posts(\\?.*)?"}]}},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/sites\/208001370\/blaze\/posts(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/sites\/208001370\/blaze\/posts(\\?.*)?"}]}},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/checkout":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/checkout"}]}},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/credits(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/sites\/208001370\/media(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/sites\/208001370\/media":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/sites\/208001370\/media"}]}},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/wpcom\/media(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/experiments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1.1\/campaigns":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1.1\/campaigns"}]}},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/sites\/208001370\/campaigns(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/stats(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/stats(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/search(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/user(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/templates\/article\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/templates\/advise\/campaign\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/templates(?P<sub_path>[a-zA-Z0-9-_\\\/:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/advise\/campaign\/(?P<urn>[a-zA-Z0-9-_:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/advise(?P<sub_path>[a-zA-Z0-9-_\\\/:]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/subscriptions(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/subscriptions(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/payments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/(?P<api_version>v[0-9]+\\.?[0-9]*)\/payments(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/smart(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/smart(?P<sub_path>[a-zA-Z0-9-_\\\/]*)":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/locations(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/woo(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/image(?P<sub_path>[a-zA-Z0-9-_\\\/]*)(\\?.*)?":{"namespace":"jetpack\/v4\/blaze-app","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/logs":{"namespace":"jetpack\/v4\/blaze-app","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze-app\/sites\/208001370\/wordads\/dsp\/api\/v1\/logs"}]}},"\/jetpack\/v4\/blaze":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/blaze","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze"}]}},"\/jetpack\/v4\/blaze\/eligibility":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze\/eligibility"}]}},"\/jetpack\/v4\/blaze\/dashboard":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze\/dashboard"}]}},"\/jetpack\/v4\/blaze\/active-campaigns":{"namespace":"jetpack\/v4\/blaze","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/blaze\/active-campaigns"}]}},"\/jetpack\/v4\/feature\/custom-content-types":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/feature\/custom-content-types"}]}},"\/jetpack\/v4\/hints":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"hint":{"default":"","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/hints"}]}},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/email-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"frequency":{"type":"string","enum":["weekly","monthly","quarterly"]},"subscribed":{"type":"boolean"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/email-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/email-reporting-next-report":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/email-reporting-next-report"}]}},"\/google-site-kit\/v1\/core\/user\/data\/initial-setup-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"hasSitePurposeAnswer":{"type":"boolean"},"isAnalyticsSetupComplete":{"type":"boolean"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/initial-setup-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false},"data":{"type":"object","description":"Impostazioni da configurare.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false},"datapoint":{"type":"string","description":"Dati del modulo indicano l'indirizzo.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificativo del modulo.","default":null,"required":false},"datapoint":{"type":"string","description":"Dati del modulo indicano l'indirizzo.","default":null,"required":false},"data":{"type":"object","description":"Dati da impostare.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/intents\/data\/intent":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"","default":null,"required":true},"intent_code":{"type":"string","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/intents\/data\/intent"}]}},"\/google-site-kit\/v1\/core\/intents\/data\/complete-intent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"slug":{"type":"string","required":true},"intent_code":{"type":"string","required":true}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/intents\/data\/complete-intent"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"Contenuto testuale da cercare.","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-eligible-subscribers":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","description":"","default":1,"minimum":1,"required":false},"per_page":{"type":"integer","description":"","default":20,"minimum":1,"maximum":100,"required":false},"search":{"type":"string","description":"","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-eligible-subscribers"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-subscribed-users":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","description":"","default":1,"minimum":1,"required":false},"per_page":{"type":"integer","description":"","default":20,"minimum":1,"maximum":100,"required":false},"search":{"type":"string","description":"","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-subscribed-users"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-unsubscribe-user":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"userID":{"type":"integer","required":true,"minimum":1}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-unsubscribe-user"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-errors":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-errors"}]}},"\/google-site-kit\/v1\/core\/site\/data\/email-reporting-invite-user":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"userID":{"type":"integer","required":true,"minimum":1}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/google-site-kit\/v1\/core\/site\/data\/email-reporting-invite-user"}]}},"\/jetpack\/v4\/import":{"namespace":"jetpack\/v4\/import","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/import","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import"}]}},"\/jetpack\/v4\/import\/blocks":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"wp_pattern_category":{"description":"I termini assegnati all'articolo nella tassonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/blocks"}]}},"\/jetpack\/v4\/import\/categories":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":true},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"parent":{"description":"Abbreviazione della categoria principale.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/categories"}]}},"\/jetpack\/v4\/import\/comments":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"author":{"description":"L'id dell'oggetto user, se l'autore \u00e8 stato un utente.","type":"integer","required":false},"author_email":{"description":"Indirizzo email dell'autore del commento.","type":"string","format":"email","required":false},"author_ip":{"description":"Indirizzo IP dell'autore del commento.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome pubblico visualizzato per l'autore del commento.","type":"string","required":false},"author_url":{"description":"L\u2019URL dell\u2019autore del commento.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User agent dell'autore del commento.","type":"string","required":false},"content":{"description":"Il contenuto del commento.","type":"object","properties":{"raw":{"description":"Il contenuto del commento, come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML del commento, adattato alla visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La data in cui il commento \u00e8 stato pubblicato, nel fuso orario del sito web.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione del commento, nel fuso orario GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"L'ID del genitore del commento.","type":"integer","required":false},"post":{"default":0,"description":"L'id dell'oggetto articolo associato.","type":"integer","required":false},"status":{"description":"Stato del commento.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Stato di risoluzione delle note","default":"","enum":["resolved","reopen"]}},"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/comments"}]}},"\/jetpack\/v4\/import\/custom-css":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/custom-css"}]}},"\/jetpack\/v4\/import\/end":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/end"}]}},"\/jetpack\/v4\/import\/global-styles":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"theme":{"description":"Il nome del tema.","type":"string","required":true},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/global-styles"}]}},"\/jetpack\/v4\/import\/media":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"upload_date":{"description":"La data per la directory di caricamento dell'allegato.","type":["string","null"],"pattern":"^\\d{4}\\\/\\d{2}$","required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":false},"alt_text":{"description":"Testo alternativo da mostrare quando la risorsa non \u00e8 visualizzata.","type":"string","required":false},"caption":{"description":"La didascalia dell'allegato.","type":"object","properties":{"raw":{"description":"Didascalia per l'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Didascalia HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La descrizione dell'allegato.","type":"object","properties":{"raw":{"description":"Descrizione dell'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Descrizione HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L'ID dell'articolo associato all'allegato.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/media"}]}},"\/jetpack\/v4\/import\/media\/(?P<id>[\\d]+)":{"namespace":"jetpack\/v4\/import","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificatore univoco per l'allegato.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"upload_date":{"description":"La data per la directory di caricamento dell'allegato.","type":["string","null"],"pattern":"^\\d{4}\\\/\\d{2}$","required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":false},"alt_text":{"description":"Testo alternativo da mostrare quando la risorsa non \u00e8 visualizzata.","type":"string","required":false},"caption":{"description":"La didascalia dell'allegato.","type":"object","properties":{"raw":{"description":"Didascalia per l'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Didascalia HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La descrizione dell'allegato.","type":"object","properties":{"raw":{"description":"Descrizione dell'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Descrizione HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L'ID dell'articolo associato all'allegato.","type":"integer","required":false}}}]},"\/jetpack\/v4\/import\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificatore univoco per l'allegato.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/jetpack\/v4\/import\/menu-items":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Il titolo dell'oggetto.","type":["string","object"],"properties":{"raw":{"description":"Il titolo dell'oggetto, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'oggetto, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La famiglia di oggetti originariamente rappresentato, come \"post_type\" o \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Uno stato con nome per l'oggetto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"L'id del genitore dell'oggetto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Testo per l'attributo title dell'elemento link per questa voce di menu.","type":"string","required":false},"classes":{"description":"Nomi della classi per l'elemento link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descrizione di questa voce di menu.","type":"string","required":false},"menu_order":{"default":1,"description":"L'ID DB di nav_menu_item che \u00e8 genitore di questa voce di menu, se presente. Altrimenti 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Il tipo di oggetto originariamente rappresentato, come \"category\", \"post\" o \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"L'ID del database dell'oggetto originale che questa voce di menu rappresenta, ad esempio l'ID per gli articoli o il term_id per le categorie.","type":"integer","minimum":0,"required":false},"target":{"description":"L'attributo target dell'elemento link per questa voce di menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L'URL al quale questa voce di menu punta.","type":"string","format":"uri","required":false},"xfn":{"description":"La relazione XFN espressa nel link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Lo slug del menu principale.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/menu-items"}]}},"\/jetpack\/v4\/import\/menus":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":true},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true},"locations":{"description":"Le posizioni assegnate al menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se aggiungere automaticamente le pagine di primo livello a questo menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/menus"}]}},"\/jetpack\/v4\/import\/navigation":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/navigation"}]}},"\/jetpack\/v4\/import\/pages":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"parent":{"description":"L'ID del genitore dell'articolo.","type":"integer","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L'ordine dell'articolo in relazione ad altri articoli.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"categories":{"items":{"type":"string"},"required":false},"tags":{"items":{"type":"string"},"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/pages"}]}},"\/jetpack\/v4\/import\/posts":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Il formato per l\u2019articolo.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"_jetpack_newsletter_access":{"type":"string","title":"","description":"","default":""},"_jetpack_dont_email_post_to_subs":{"type":"boolean","title":"","description":"","default":false},"_jetpack_newsletter_tier_id":{"type":"integer","title":"","description":"","default":0},"_jetpack_memberships_contains_paywalled_content":{"type":"boolean","title":"","description":"","default":false},"_jetpack_feature_clip_id":{"type":"integer","title":"","description":"Attachment ID of the generated video clip designated as this post's feature clip.","default":0},"_jetpack_memberships_contains_paid_content":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Se l'articolo \u00e8 mai stato pubblicato.","default":false}},"required":false},"sticky":{"description":"Se l'articolo sia da trattare come in evidenza o meno.","type":"boolean","required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"categories":{"description":"I termini assegnati all'articolo nella tassonomia category.","type":"array","items":{"type":"string"},"required":false},"tags":{"description":"I termini assegnati all'articolo nella tassonomia post_tag.","type":"array","items":{"type":"string"},"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/posts"}]}},"\/jetpack\/v4\/import\/start":{"namespace":"jetpack\/v4\/import","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/start"}]}},"\/jetpack\/v4\/import\/tags":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":true},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/tags"}]}},"\/jetpack\/v4\/import\/template-parts":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"default":"","description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descrizione del template.","type":"string","required":false},"status":{"default":"publish","description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"area":{"description":"Si intende quella parte o sezione del template destinata ad un uso specifico (header, footer, ecc.)","type":"string","required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/template-parts"}]}},"\/jetpack\/v4\/import\/templates":{"namespace":"jetpack\/v4\/import","methods":["POST"],"endpoints":[{"methods":["POST"],"allow_batch":{"v1":true},"args":{"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"default":"","description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descrizione del template.","type":"string","required":false},"status":{"default":"publish","description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"unified_importer_id":{"description":"Importa l'identificativo univoco di Jetpack per il termine.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/import\/templates"}]}},"\/wpcom\/v2":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2"}]}},"\/wpcom\/v2\/videopress\/meta":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L'ID dell'articolo per l'allegato.","type":"integer","required":true},"title":{"description":"Il titolo del video.","type":"string","required":false},"description":{"description":"La descrizione del video.","type":"string","required":false},"caption":{"description":"La didascalia del video.","type":"string","required":false},"rating":{"description":"La classificazione del contenuto del video. Uno tra G, PG-13 o R-17","type":"string","required":false},"display_embed":{"description":"Mostra il menu di condivisione nel lettore.","type":"boolean","required":false},"allow_download":{"description":"Mostra l'opzione di download e permetti ai visitatori di scaricare questo video","type":"boolean","required":false},"privacy_setting":{"description":"Come determinare se il video deve essere pubblico o privato","type":"integer","enum":[0,1,2],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/videopress\/meta"}]}},"\/wpcom\/v2\/videopress\/(?P<video_guid>[A-Za-z0-9]{8})\/poster":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"video_guid":{"description":"GUID VideoPress.","type":"string","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"video_guid":{"description":"GUID VideoPress.","type":"string","required":true},"at_time":{"description":"Il tempo nel video da utilizzare come cornice del poster.","type":"integer","required":false},"is_millisec":{"description":"Se il tempo \u00e8 in millisecondi o secondi.","type":"boolean","required":false},"poster_attachment_id":{"description":"L'ID allegato dell'immagine poster","type":"integer","required":false}}}]},"\/wpcom\/v2\/videopress\/(?P<video_guid>[A-Za-z0-9]{8})\/check-ownership\/(?P<post_id>\\d+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"video_guid":{"description":"GUID VideoPress.","type":"string","required":true},"post_id":{"description":"L'ID dell'articolo per l'allegato.","type":"integer","required":true}}}]},"\/wpcom\/v2\/videopress\/upload-jwt":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/videopress\/upload-jwt"}]}},"\/wpcom\/v2\/videopress\/playback-jwt\/(?P<video_guid>[A-Za-z0-9]{8})":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"video_guid":{"description":"GUID VideoPress.","type":"string","required":true},"post_id":{"description":"L'articolo in cui \u00e8 incorporato il video, utilizzato per autorizzare l'accesso.","type":"integer","required":false},"subscription_plan_id":{"description":"Il piano di abbonamento usato dal blocco di contenuti premium che controlla il video.","type":"integer","required":false}}}]},"\/wpcom\/v2\/videopress\/settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"videopress_videos_private_for_site":{"description":"Se i video di VideoPress devono essere privati per impostazione predefinita","type":"boolean","required":false},"videopress_auto_subtitles_disabled":{"description":"Se i sottotitoli generati automaticamente devono essere saltati per i nuovi video","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/videopress\/settings"}]}},"\/wpcom\/v2\/videopress\/promote\/(?P<attachment_id>\\d+)":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"attachment_id":{"description":"L'ID allegato del video da promuovere.","type":"integer","required":true}}}]},"\/wpcom\/v2\/videopress\/caption-tracks":{"namespace":"wpcom\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"guid":{"description":"GUID VideoPress.","type":"string","required":true}}},{"methods":["POST"],"args":{"guid":{"description":"GUID VideoPress.","type":"string","required":false},"title":{"description":"Titolo della traccia dei sottotitoli.","type":"string","required":false},"content":{"description":"Contenuto del blocco di sottotitoli serializzato.","type":"string","required":false},"status":{"description":"Stato della traccia dei sottotitoli.","type":"string","enum":["draft","publish"],"required":false},"meta":{"description":"Metadati della traccia dei sottotitoli.","type":"object","properties":{"_videopress_guid":{"type":"string"},"_videopress_caption_kind":{"type":"string"},"_videopress_caption_src_lang":{"type":"string"},"_videopress_caption_label":{"type":"string"},"_videopress_source_track_kind":{"type":"string"},"_videopress_source_track_src_lang":{"type":"string"},"_videopress_source_track_src":{"type":"string"}},"additionalProperties":false,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/videopress\/caption-tracks"}]}},"\/wpcom\/v2\/videopress\/caption-tracks\/(?P<id>\\d+)":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID traccia sottotitoli.","type":"integer","required":true},"guid":{"description":"GUID VideoPress.","type":"string","required":false},"title":{"description":"Titolo della traccia dei sottotitoli.","type":"string","required":false},"content":{"description":"Contenuto del blocco di sottotitoli serializzato.","type":"string","required":false},"status":{"description":"Stato della traccia dei sottotitoli.","type":"string","enum":["draft","publish"],"required":false},"meta":{"description":"Metadati della traccia dei sottotitoli.","type":"object","properties":{"_videopress_guid":{"type":"string"},"_videopress_caption_kind":{"type":"string"},"_videopress_caption_src_lang":{"type":"string"},"_videopress_caption_label":{"type":"string"},"_videopress_source_track_kind":{"type":"string"},"_videopress_source_track_src_lang":{"type":"string"},"_videopress_source_track_src":{"type":"string"}},"additionalProperties":false,"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"ID traccia sottotitoli.","type":"integer","required":true}}}]},"\/jetpack\/v4\/stats\/blog":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/stats\/blog"}]}},"\/jetpack-boost\/v1":{"namespace":"jetpack-boost\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack-boost\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack-boost\/v1"}]}},"\/jetpack-boost\/v1\/speed-scores":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack-boost\/v1\/speed-scores"}]}},"\/jetpack-boost\/v1\/speed-scores\/refresh":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack-boost\/v1\/speed-scores\/refresh"}]}},"\/jetpack-boost\/v1\/speed-scores-history":{"namespace":"jetpack-boost\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"start":{"type":"number","required":true},"end":{"type":"number","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack-boost\/v1\/speed-scores-history"}]}},"\/my-jetpack\/v1":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"my-jetpack\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1"}]}},"\/my-jetpack\/v1\/site\/products":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"products":{"description":"Elenco separato da virgole degli slug di prodotto che devono essere recuperati.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/products"}]}},"\/my-jetpack\/v1\/site\/products\/install":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Matrice di slug di prodotti","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/products\/install"}]}},"\/my-jetpack\/v1\/site\/products\/activate":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Matrice di slug di prodotti","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/products\/activate"}]}},"\/my-jetpack\/v1\/site\/products\/interstitials":{"namespace":"my-jetpack\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"products":{"description":"Coppie chiave-valore degli slug del prodotto e dello stato dei loro annunci interstiziali.","type":"object","properties":{"anti-spam":{"type":"boolean"},"backup":{"type":"boolean"},"boost":{"type":"boolean"},"crm":{"type":"boolean"},"creator":{"type":"boolean"},"extras":{"type":"boolean"},"jetpack-ai":{"type":"boolean"},"ai":{"type":"boolean"},"scan":{"type":"boolean"},"search":{"type":"boolean"},"social":{"type":"boolean"},"security":{"type":"boolean"},"protect":{"type":"boolean"},"videopress":{"type":"boolean"},"stats":{"type":"boolean"},"growth":{"type":"boolean"},"complete":{"type":"boolean"},"newsletter":{"type":"boolean"},"site-accelerator":{"type":"boolean"},"related-posts":{"type":"boolean"},"jetpack-forms":{"type":"boolean"}},"additionalProperties":false,"minProperties":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/products\/interstitials"}]}},"\/my-jetpack\/v1\/site\/products\/deactivate":{"namespace":"my-jetpack\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"products":{"description":"Matrice di slug di prodotti","type":"array","items":{"enum":["anti-spam","backup","boost","crm","creator","extras","jetpack-ai","ai","scan","search","social","security","protect","videopress","stats","growth","complete","newsletter","site-accelerator","related-posts","jetpack-forms"],"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/products\/deactivate"}]}},"\/my-jetpack\/v1\/site\/products-ownership":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/products-ownership"}]}},"\/my-jetpack\/v1\/site\/purchases":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/purchases"}]}},"\/my-jetpack\/v1\/chat\/availability":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/chat\/availability"}]}},"\/my-jetpack\/v1\/chat\/authentication":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"test_mode":{"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/chat\/authentication"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation"}]}},"\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/recommendations\/evaluation\/result"}]}},"\/my-jetpack\/v1\/site\/backup\/undo-event":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/backup\/undo-event"}]}},"\/my-jetpack\/v1\/site\/protect\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/protect\/data"}]}},"\/my-jetpack\/v1\/site\/videopress\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/videopress\/data"}]}},"\/my-jetpack\/v1\/site\/update-historically-active-modules":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/update-historically-active-modules"}]}},"\/my-jetpack\/v1\/jetpack-manage\/data":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/jetpack-manage\/data"}]}},"\/my-jetpack\/v1\/red-bubble-notifications":{"namespace":"my-jetpack\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dismissal_cookies":{"type":"array","description":"Array of dismissal cookies to set for the red bubble notifications.","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/red-bubble-notifications"}]}},"\/my-jetpack\/v1\/site":{"namespace":"my-jetpack\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site"}]}},"\/my-jetpack\/v1\/site\/dismiss-welcome-banner":{"namespace":"my-jetpack\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/my-jetpack\/v1\/site\/dismiss-welcome-banner"}]}},"\/jetpack\/v4\/explat":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jetpack\/v4\/explat","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/explat"}]}},"\/jetpack\/v4\/explat\/assignments":{"namespace":"jetpack\/v4\/explat","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"experiment_name":{"type":"string","required":false},"anon_id":{"type":"string","required":false},"as_connected_user":{"type":"boolean","required":false},"platform":{"type":"string","enum":["jetpack","calypso","wpcom"],"default":"jetpack","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/explat\/assignments"}]}},"\/wpcom\/v2\/business-hours\/localized-week":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/business-hours\/localized-week"}]}},"\/wpcom\/v2\/admin-bar":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/admin-bar"}]}},"\/wpcom\/v2\/admin-color":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/admin-color"}]}},"\/wpcom\/v2\/admin-menu":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/admin-menu"}]}},"\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/jetpack-ai\/ai-assistant-feature"}]}},"\/wpcom\/v2\/app-media":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"description":"Numero di elementi multimediali in questa richiesta","type":"number","default":20,"required":false},"page_handle":{"type":"number","default":1,"required":false},"after":{"description":"Data e ora dal momento in cui il media \u00e8 stato caricato","type":"number","default":0,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/app-media"}]}},"\/wpcom\/v2\/application-password-extras\/abilities":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/application-password-extras\/abilities"}]}},"\/wpcom\/v2\/application-password-extras\/admin-ajax":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/application-password-extras\/admin-ajax"}]}},"\/wpcom\/v2\/editor-assets":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"exclude":{"description":"Elenco di tipi di asset separati da virgole da escludere dalla risposta. Valori supportati: \"core\" (risorse di base di WordPress), \"gutenberg\" (risorse del plugin Gutenberg) o prefissi dell'handle del plugin (ad esempio, \"contact-form-7\").","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/editor-assets"}]}},"\/wpcom\/v2\/blog-stats":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"description":"ID articolo per il quale ottenere statistiche.","type":["string","integer"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/blog-stats"}]}},"\/wpcom\/v2\/email-preview":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificatore univoco per l'articolo.","type":"integer","required":false},"access":{"description":"Livello di accesso.","enum":["everybody","subscribers","paid_subscribers"],"default":"everybody","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/email-preview"}]}},"\/wpcom\/v2\/external-media\/list\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"description":"Termine di ricerca di raccolta degli elementi multimediali.","type":"string","required":false},"number":{"description":"Numero di elementi multimediali in questa richiesta","type":"number","default":20,"required":false},"path":{"type":"string","required":false},"page_handle":{"type":"string","required":false},"session_id":{"description":"ID sessione di un servizio, al momento solo Google Photos Picker","type":"string","required":false}}}]},"\/wpcom\/v2\/external-media\/copy\/(?P<service>google_photos|openverse|pexels)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"media":{"description":"Metadati da copiare.","items":{"type":"array","items":{"type":"object","required":true,"properties":{"caption":{"type":"string"},"guid":{"type":"object","properties":{"caption":{"type":"string"},"name":{"type":"string"},"title":{"type":"string"},"url":{"format":"uri","type":"string"}}},"title":{"type":"string"},"meta":{"type":"object","additionalProperties":false,"properties":{"vertical_id":{"type":"string","format":"text-field"},"pexels_object":{"type":"object"}}}}}},"type":"array","required":true},"post_id":{"description":"ID dell'articolo per allegare il caricamento.","type":"number","minimum":0,"required":false},"should_proxy":{"description":"Se usare un proxy per la richiesta di media.","type":"boolean","default":false,"required":false}}}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/wpcom\/v2\/external-media\/connection\/(?P<service>google_photos)\/picker_status":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/wpcom\/v2\/external-media\/session\/(?P<service>google_photos)\/(?P<session_id>.*)":{"namespace":"wpcom\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/wpcom\/v2\/external-media\/proxy\/(?P<service>google_photos)":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"url":{"type":"string","required":true}}}]},"\/wpcom\/v2\/following\/mine":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ignore_user_blogs":{"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/following\/mine"}]}},"\/wpcom\/v2\/following\/recommendations":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"number":{"type":"number","default":5,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/following\/recommendations"}]}},"\/wpcom\/v2\/goodreads\/user-id":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID utente Goodreads","type":"integer","minimum":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/goodreads\/user-id"}]}},"\/wpcom\/v2\/checkGoogleDocVisibility":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/checkGoogleDocVisibility"}]}},"\/wpcom\/v2\/instagram-gallery\/connect-url":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/instagram-gallery\/connect-url"}]}},"\/wpcom\/v2\/instagram-gallery\/connections":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/instagram-gallery\/connections"}]}},"\/wpcom\/v2\/instagram-gallery\/gallery":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"access_token":{"description":"Un token di accesso del keyring di Instagram.","type":"integer","minimum":1,"required":true},"count":{"description":"Quanti articoli su Instagram?","type":"integer","minimum":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/instagram-gallery\/gallery"}]}},"\/wpcom\/v2\/mailchimp":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/mailchimp"}]}},"\/wpcom\/v2\/mailchimp\/groups":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/mailchimp\/groups"}]}},"\/wpcom\/v2\/mailchimp\/settings":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/mailchimp\/settings"}]}},"\/wpcom\/v2\/jetpack-ai\/mcp-settings":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"mcp_abilities":{"type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/jetpack-ai\/mcp-settings"}]}},"\/wpcom\/v2\/newsletter-categories":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/newsletter-categories"}]}},"\/wpcom\/v2\/newsletter-categories\/count":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term_ids":{"default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/newsletter-categories\/count"}]}},"\/wpcom\/v2\/newsletter-categories\/subscriptions\/(?P<subscription_id>[0-9]+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"required":true},"type":{"required":false}}}]},"\/wpcom\/v2\/newsletter-email-sent-status":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/newsletter-email-sent-status"}]}},"\/wpcom\/v2\/podcast-player":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L'URL di feed RSS del podcast.","type":"string","required":true},"guids":{"description":"Un elenco di identificatori univoci per il recupero di episodi specifici del podcast.","type":"array","required":true},"episode-options":{"description":"Se dobbiamo restituire l'elenco degli episodi da utilizzare nell'interfaccia della selezione","type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/podcast-player"}]}},"\/wpcom\/v2\/podcast-player\/track-quantity":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/podcast-player\/track-quantity"}]}},"\/wpcom\/v2\/profile":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/profile"}]}},"\/wpcom\/v2\/related-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/related-posts"}]}},"\/wpcom\/v2\/related-posts\/enable":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/related-posts\/enable"}]}},"\/wpcom\/v2\/related-posts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificatore univoco per l'articolo.","type":"integer","required":false}}}]},"\/wpcom\/v2\/resolve-redirect\/?(?P<url>.+)?":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L'URL da verificare per la presenza di reindirizzamenti.","type":"string","required":true}}}]},"\/wpcom\/v2\/search":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/search"}]}},"\/wpcom\/v2\/send-email-preview":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificatore univoco per l'articolo.","type":"integer","required":false},"email":{"description":"Indirizzo del destinatario facoltativo. Ha come valore predefinito l'utente corrente. Un indirizzo diverso \u00e8 accettato solo dagli utenti che possono aggiungere abbonati ed \u00e8 soggetto agli stessi controlli sugli abusi.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/send-email-preview"}]}},"\/wpcom\/v2\/subscribers\/add":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"emails":{"type":"array","items":{"type":"string"},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/add"}]}},"\/wpcom\/v2\/subscribers\/remove":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"user_id":{"type":"integer","default":0,"minimum":0,"required":false},"email_subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"paid_subscription_ids":{"type":"array","items":{"type":"string"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/remove"}]}},"\/wpcom\/v2\/subscribers\/individual":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"user_id":{"type":"integer","default":0,"minimum":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/individual"}]}},"\/wpcom\/v2\/subscribers\/individual-stats":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"subscription_id":{"type":"integer","default":0,"minimum":0,"required":false},"user_id":{"type":"integer","default":0,"minimum":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/individual-stats"}]}},"\/wpcom\/v2\/subscribers\/import":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/import"}]}},"\/wpcom\/v2\/subscribers\/import\/reset-state":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/import\/reset-state"}]}},"\/wpcom\/v2\/subscribers\/totals":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/totals"}]}},"\/wpcom\/v2\/subscribers\/list":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"type":"integer","default":1,"minimum":1,"required":false},"per_page":{"type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"sort":{"type":"string","default":"date_subscribed","enum":["date_subscribed","name","plan","subscription_status"],"required":false},"sort_order":{"type":"string","default":"desc","enum":["asc","desc"],"required":false},"search":{"type":"string","default":"","required":false},"filters":{"type":"array","items":{"type":"string"},"default":["all"],"required":false},"use_new_helper":{"type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/list"}]}},"\/wpcom\/v2\/subscribers\/products":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/products"}]}},"\/wpcom\/v2\/subscribers\/comp":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"user_id":{"type":"integer","minimum":1,"required":true},"plan_id":{"type":"integer","minimum":1,"required":true},"no_expiration":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/comp"}]}},"\/wpcom\/v2\/subscribers\/remove-comp":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"comp_id":{"type":"integer","minimum":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/remove-comp"}]}},"\/wpcom\/v2\/template-loader\/(?P<template_type>\\w+)":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"template_type":{"description":"Il tipo di modello","type":"string","required":true}}}]},"\/wpcom\/v2\/post-types":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/post-types"}]}},"\/wpcom\/v2\/top-posts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"period":{"description":"Intervallo temporale per le statistiche.","type":["string","integer"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/top-posts"}]}},"\/wpcom\/v2\/transients\/(?P<name>\\w{1,172})":{"namespace":"wpcom\/v2","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"name":{"description":"Il nome del transient da eliminare.","type":"string","required":true}}}]},"\/wpcom\/v3":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpcom\/v3","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v3"}]}},"\/wpcom\/v3\/blogging-prompts":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"after":{"description":"Mostra i prompt successivi a una data specifica.","type":"string","required":false},"before":{"description":"Mostra i prompt prima di una data specifica.","type":"string","required":false},"force_year":{"description":"Forza le richieste restituite in modo che siano per un anno specifico. Restituisce solamente una richiesta per ogni giorno.","type":"integer","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v3\/blogging-prompts"}]}},"\/wpcom\/v3\/blogging-prompts\/(?P<id>[\\d]+)":{"namespace":"wpcom\/v3","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificatore univoco per il prompt.","type":"integer","required":false}}}]},"\/wpcom\/v3\/jitm":{"namespace":"wpcom\/v3","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"message_path":{"type":"string","description":"Il percorso del messaggio per cui recuperare JITM","required":true},"query":{"type":"string","description":"Parametri di query aggiuntivi","required":false},"full_jp_logo_exists":{"type":"boolean","description":"Se esiste il logo Jetpack completo","required":false}}},{"methods":["POST"],"args":{"id":{"type":"string","description":"ID del JITM da ignorare","required":true},"feature_class":{"type":"string","description":"La classe di funzionalit\u00e0 del JITM","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v3\/jitm"}]}},"\/wpcom\/v2\/gutenberg\/available-extensions":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/gutenberg\/available-extensions"}]}},"\/wpcom\/v2\/hello":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/hello"}]}},"\/wpcom\/v2\/memberships\/status\/?":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"source":{"type":"string","required":false},"is_editable":{"type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/memberships\/status\/?"}]}},"\/wpcom\/v2\/memberships\/product\/?":{"namespace":"wpcom\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"title":{"type":"string","required":true},"price":{"type":"number","required":true},"currency":{"type":"string","required":true},"interval":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false},"buyer_can_change_amount":{"type":"boolean","required":false},"tier":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/memberships\/product\/?"}]}},"\/wpcom\/v2\/memberships\/products\/?":{"namespace":"wpcom\/v2","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"currency":{"type":"string","required":true},"type":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false}}},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/memberships\/products\/?"}]}},"\/wpcom\/v2\/memberships\/product\/(?P<product_id>[0-9]+)\/?":{"namespace":"wpcom\/v2","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"title":{"type":"string","required":true},"price":{"type":"number","required":true},"currency":{"type":"string","required":true},"interval":{"type":"string","required":true},"is_editable":{"type":"boolean","required":false},"buyer_can_change_amount":{"type":"boolean","required":false},"tier":{"type":"integer","required":false},"description":{"type":"string","required":false}}},{"methods":["DELETE"],"args":{"cancel_subscriptions":{"type":"boolean","required":false}}}]},"\/wpcom\/v2\/publicize\/connection-test-results":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/publicize\/connection-test-results"}]}},"\/wpcom\/v2\/service-api-keys\/(?P<service>[a-z\\-_]+)":{"namespace":"wpcom\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"service_api_key":{"type":"string","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wpcom\/v2\/subscribers\/count":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/count"}]}},"\/wpcom\/v2\/subscribers\/counts":{"namespace":"wpcom\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wpcom\/v2\/subscribers\/counts"}]}},"\/jetpack\/v4\/remote_authorize":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/remote_authorize"}]}},"\/jetpack\/v4\/remote_provision":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/remote_provision"}]}},"\/jetpack\/v4\/remote_register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/remote_register"}]}},"\/jetpack\/v4\/remote_connect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/remote_connect"}]}},"\/jetpack\/v4\/connection\/check":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/check"}]}},"\/jetpack\/v4\/connection\/test":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/test"}]}},"\/jetpack\/v4\/connection\/test-wpcom":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/test-wpcom"}]}},"\/jetpack\/v4\/connection":{"namespace":"jetpack\/v4","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"isActive":{"description":"L'impostazione su falso attiver\u00e0 la disconnessione del sito.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection"}]}},"\/jetpack\/v4\/connection\/user":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/user"}]}},"\/jetpack\/v4\/connection\/data":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/data"}]}},"\/jetpack\/v4\/connection\/plugins":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/plugins"}]}},"\/jetpack\/v4\/connection\/reconnect":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/reconnect"}]}},"\/jetpack\/v4\/connection\/register":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"from":{"description":"Indica il punto in cui l'azione della registrazione \u00e8 stata attivata per scopi di tracciabilit\u00e0\/segmentazione","type":"string","required":false},"redirect_uri":{"description":"URI della pagina di amministrazione a cui l'utente dovrebbe essere rendirizzato dopo il flusso di connessione","type":"string","required":false},"plugin_slug":{"description":"Indica da quale plugin proviene la richiesta","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/register"}]}},"\/jetpack\/v4\/connection\/authorize_url":{"namespace":"jetpack\/v4","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"redirect_uri":{"description":"URI della pagina di amministrazione a cui l'utente dovrebbe essere rendirizzato dopo il flusso di connessione","type":"string","required":false},"from":{"description":"Identificatore di tracciamento\/segmentazione per questa richiesta URL di autorizzazione","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/authorize_url"}]}},"\/jetpack\/v4\/user-token":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"user_token":{"description":"Nuovo token utente","type":"string","required":true},"is_connection_owner":{"description":"\u00c8 il proprietario della connessione","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/user-token"}]}},"\/jetpack\/v4\/connection\/owner":{"namespace":"jetpack\/v4","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"owner":{"description":"Nuovo proprietario","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/jetpack\/v4\/connection\/owner"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limita la serie di risultati agli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantisce che la serie di risultati escluda gli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita i risultati basati sulle relazioni tra tassonomie multiple.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limita l'insieme dei risultati agli elementi con i termini specifici assegnati nella tassonomia categories.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Se i termini figli sono inclusi nei termini che limitano il set di risultati.","type":"boolean","default":false},"operator":{"description":"Se gli elementi devono essere assegnati a tutti o ad alcuni dei termini specificati.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limita l'insieme dei risultati agli elementi tranne quelli con termini specifici assegnati nella tassonomia categories.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Se i termini figli sono inclusi nei termini che limitano il set di risultati.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limita l'insieme dei risultati agli elementi con i termini specifici assegnati nella tassonomia tags.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se gli elementi devono essere assegnati a tutti o ad alcuni dei termini specificati.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limita l'insieme dei risultati agli elementi tranne quelli con termini specifici assegnati nella tassonomia tags.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limita la serie di risultati agli elementi in evidenza.","type":"boolean","required":false},"ignore_sticky":{"description":"Se ignorare o meno gli articoli in evidenza.","type":"boolean","default":true,"required":false},"format":{"description":"Limita i risultati agli elementi assegnati ad uno o pi\u00f9 formati specifici.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Il formato per l\u2019articolo.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"_jetpack_newsletter_access":{"type":"string","title":"","description":"","default":""},"_jetpack_dont_email_post_to_subs":{"type":"boolean","title":"","description":"","default":false},"_jetpack_newsletter_tier_id":{"type":"integer","title":"","description":"","default":0},"_jetpack_memberships_contains_paywalled_content":{"type":"boolean","title":"","description":"","default":false},"_jetpack_feature_clip_id":{"type":"integer","title":"","description":"Attachment ID of the generated video clip designated as this post's feature clip.","default":0},"_jetpack_memberships_contains_paid_content":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Se l'articolo \u00e8 mai stato pubblicato.","default":false}},"required":false},"sticky":{"description":"Se l'articolo sia da trattare come in evidenza o meno.","type":"boolean","required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"categories":{"description":"I termini assegnati all'articolo nella tassonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"I termini assegnati all'articolo nella tassonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Sovrascrivi la lunghezza predefinita del riassunto.","type":"integer","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Il formato per l\u2019articolo.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"_jetpack_newsletter_access":{"type":"string","title":"","description":"","default":""},"_jetpack_dont_email_post_to_subs":{"type":"boolean","title":"","description":"","default":false},"_jetpack_newsletter_tier_id":{"type":"integer","title":"","description":"","default":0},"_jetpack_memberships_contains_paywalled_content":{"type":"boolean","title":"","description":"","default":false},"_jetpack_feature_clip_id":{"type":"integer","title":"","description":"Attachment ID of the generated video clip designated as this post's feature clip.","default":0},"_jetpack_memberships_contains_paid_content":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Se l'articolo \u00e8 mai stato pubblicato.","default":false}},"required":false},"sticky":{"description":"Se l'articolo sia da trattare come in evidenza o meno.","type":"boolean","required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"categories":{"description":"I termini assegnati all'articolo nella tassonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"I termini assegnati all'articolo nella tassonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base ad un attributo dell'oggetto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 le revisioni non si possono eliminare.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Il formato per l\u2019articolo.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"_jetpack_newsletter_access":{"type":"string","title":"","description":"","default":""},"_jetpack_dont_email_post_to_subs":{"type":"boolean","title":"","description":"","default":false},"_jetpack_newsletter_tier_id":{"type":"integer","title":"","description":"","default":0},"_jetpack_memberships_contains_paywalled_content":{"type":"boolean","title":"","description":"","default":false},"_jetpack_feature_clip_id":{"type":"integer","title":"","description":"Attachment ID of the generated video clip designated as this post's feature clip.","default":0},"_jetpack_memberships_contains_paid_content":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""},"jetpack_post_was_ever_published":{"type":"boolean","title":"","description":"Se l'articolo \u00e8 mai stato pubblicato.","default":false}},"required":false},"sticky":{"description":"Se l'articolo sia da trattare come in evidenza o meno.","type":"boolean","required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"categories":{"description":"I termini assegnati all'articolo nella tassonomia category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"I termini assegnati all'articolo nella tassonomia post_tag.","type":"array","items":{"type":"integer"},"required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limita la serie di risultati agli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantisce che la serie di risultati escluda gli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limita l'insieme di risultati agli articoli con uno specifico valore menu_order.","type":"integer","required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limita la serie di risultati dei particolari parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita il risultato a tutti gli elementi eccetto quelli di un particolare ID genitore.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"parent":{"description":"L'ID del genitore dell'articolo.","type":"integer","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L'ordine dell'articolo in relazione ad altri articoli.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Sovrascrivi la lunghezza predefinita del riassunto.","type":"integer","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"parent":{"description":"L'ID del genitore dell'articolo.","type":"integer","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L'ordine dell'articolo in relazione ad altri articoli.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base ad un attributo dell'oggetto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 le revisioni non si possono eliminare.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L'ID del genitore dell'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L'ordine dell'articolo in relazione ad altri articoli.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limita la serie di risultati agli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantisce che la serie di risultati escluda gli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limita la serie di risultati dei particolari parent ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limita il risultato a tutti gli elementi eccetto quelli di un particolare ID genitore.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limita il set di risultati agli allegati di un particolare tipo o tipi di media.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limita il set di risultati agli allegati di un particolare tipo MIME o tipi MIME.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false},"alt_text":{"description":"Testo alternativo da mostrare quando la risorsa non \u00e8 visualizzata.","type":"string","required":false},"caption":{"description":"La didascalia dell'allegato.","type":"object","properties":{"raw":{"description":"Didascalia per l'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Didascalia HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La descrizione dell'allegato.","type":"object","properties":{"raw":{"description":"Descrizione dell'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Descrizione HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L'ID dell'articolo associato all'allegato.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"comment_status":{"description":"Se i commenti sono aperti o meno per l'articolo.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Se l'articolo si possa pingare o meno.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"aioseo_meta_data":{"type":"object","required":false},"_aioseop_title":{"type":"string","required":false},"_aioseop_description":{"type":"string","required":false},"jetpack_sharing_enabled":{"description":"I pulsante di condivisione sono abilitati?","type":"boolean","required":false},"alt_text":{"description":"Testo alternativo da mostrare quando la risorsa non \u00e8 visualizzata.","type":"string","required":false},"caption":{"description":"La didascalia dell'allegato.","type":"object","properties":{"raw":{"description":"Didascalia per l'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Didascalia HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La descrizione dell'allegato.","type":"object","properties":{"raw":{"description":"Descrizione dell'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Descrizione HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L'ID dell'articolo associato all'allegato.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificatore univoco per l'allegato.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL al file dell'immagine modificata.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array delle modifiche dell'immagine.","type":"array","minItems":1,"items":{"description":"Modifica delle immagini.","type":"object","required":["type","args"],"oneOf":[{"title":"Capovolgi","properties":{"type":{"description":"Tipo di capovolgi.","type":"string","enum":["flip"]},"args":{"description":"Argomenti di capovolgi.","type":"object","required":["flip"],"properties":{"flip":{"description":"Direzione di capovolgimento.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Se capovolgere in direzione orizzontale.","type":"boolean"},"vertical":{"description":"Se capovolgere in direzione verticale.","type":"boolean"}}}}}}},{"title":"Rotazione","properties":{"type":{"description":"Tipo di rotazione.","type":"string","enum":["rotate"]},"args":{"description":"Argomenti della rotazione.","type":"object","required":["angle"],"properties":{"angle":{"description":"Angolo in gradi per la rotazione in senso orario.","type":"number"}}}}},{"title":"Ritaglia","properties":{"type":{"description":"Tipo di ritaglia.","type":"string","enum":["crop"]},"args":{"description":"Argomenti di ritaglia.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Distanza orizzontale da sinistra per iniziare il ritaglio in percentuale della larghezza dell'immagine.","type":"number"},"top":{"description":"Distanza verticale dall'alto per iniziare il ritaglio in percentuale dell'altezza dell'immagine.","type":"number"},"width":{"description":"Larghezza del crop come percentuale della larghezza dell'immagine.","type":"number"},"height":{"description":"Altezza del crop come percentuale dell'altezza dell'immagine.","type":"number"}}}}}]},"required":false},"rotation":{"description":"I gradi in senso orario di rotazione dell'immagine. DEPRECATO: preferire i `modifiers`.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"La posizione x da cui iniziare il ritaglio dell'immagine. DEPRECATO: preferire i `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"La posizione y da cui iniziare il ritaglio dell'immagine. DEPRECATO: preferire i `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"La larghezza di ritaglio dell'immagine in percentuale dell'immagine. DEPRECATO: preferire i `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"L'altezza di ritaglio dell'immagine in percentuale dell'immagine. DEPRECATO: preferire i `modifiers`.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"La didascalia dell'allegato.","type":"object","properties":{"raw":{"description":"Didascalia per l'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Didascalia HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La descrizione dell'allegato.","type":"object","properties":{"raw":{"description":"Descrizione dell'allegato, cos\u00ec come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Descrizione HTML per l'allegato, trasformata per la visualizzazione.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"L'ID dell'articolo associato all'allegato.","type":"integer","required":false},"alt_text":{"description":"Testo alternativo da mostrare quando la risorsa non \u00e8 visualizzata.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base ad un attributo dell'oggetto.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita i risultati basati sulle relazioni tra tassonomie multiple.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limita l'insieme dei risultati agli elementi con i termini specifici assegnati nella tassonomia menus.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se gli elementi devono essere assegnati a tutti o ad alcuni dei termini specificati.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limita l'insieme dei risultati agli elementi tranne quelli con termini specifici assegnati nella tassonomia menus.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limita l'insieme di risultati agli articoli con uno specifico valore menu_order.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Il titolo dell'oggetto.","type":["string","object"],"properties":{"raw":{"description":"Il titolo dell'oggetto, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'oggetto, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La famiglia di oggetti originariamente rappresentato, come \"post_type\" o \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Uno stato con nome per l'oggetto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"L'id del genitore dell'oggetto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Testo per l'attributo title dell'elemento link per questa voce di menu.","type":"string","required":false},"classes":{"description":"Nomi della classi per l'elemento link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descrizione di questa voce di menu.","type":"string","required":false},"menu_order":{"default":1,"description":"L'ID DB di nav_menu_item che \u00e8 genitore di questa voce di menu, se presente. Altrimenti 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Il tipo di oggetto originariamente rappresentato, come \"category\", \"post\" o \"attachment\".","type":"string","required":false},"object_id":{"default":0,"description":"L'ID del database dell'oggetto originale che questa voce di menu rappresenta, ad esempio l'ID per gli articoli o il term_id per le categorie.","type":"integer","minimum":0,"required":false},"target":{"description":"L'attributo target dell'elemento link per questa voce di menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L'URL al quale questa voce di menu punta.","type":"string","format":"uri","required":false},"xfn":{"description":"La relazione XFN espressa nel link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"I termini assegnati all'oggetto nella tassonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"title":{"description":"Il titolo dell'oggetto.","type":["string","object"],"properties":{"raw":{"description":"Il titolo dell'oggetto, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'oggetto, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famiglia di oggetti originariamente rappresentato, come \"post_type\" o \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Uno stato con nome per l'oggetto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"L'id del genitore dell'oggetto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Testo per l'attributo title dell'elemento link per questa voce di menu.","type":"string","required":false},"classes":{"description":"Nomi della classi per l'elemento link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descrizione di questa voce di menu.","type":"string","required":false},"menu_order":{"description":"L'ID DB di nav_menu_item che \u00e8 genitore di questa voce di menu, se presente. Altrimenti 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Il tipo di oggetto originariamente rappresentato, come \"category\", \"post\" o \"attachment\".","type":"string","required":false},"object_id":{"description":"L'ID del database dell'oggetto originale che questa voce di menu rappresenta, ad esempio l'ID per gli articoli o il term_id per le categorie.","type":"integer","minimum":0,"required":false},"target":{"description":"L'attributo target dell'elemento link per questa voce di menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L'URL al quale questa voce di menu punta.","type":"string","format":"uri","required":false},"xfn":{"description":"La relazione XFN espressa nel link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"I termini assegnati all'oggetto nella tassonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L'id del genitore dell'oggetto.","type":"integer","minimum":0,"required":false},"title":{"description":"Il titolo dell'oggetto.","type":["string","object"],"properties":{"raw":{"description":"Il titolo dell'oggetto, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'oggetto, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famiglia di oggetti originariamente rappresentato, come \"post_type\" o \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Uno stato con nome per l'oggetto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Testo per l'attributo title dell'elemento link per questa voce di menu.","type":"string","required":false},"classes":{"description":"Nomi della classi per l'elemento link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descrizione di questa voce di menu.","type":"string","required":false},"menu_order":{"description":"L'ID DB di nav_menu_item che \u00e8 genitore di questa voce di menu, se presente. Altrimenti 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Il tipo di oggetto originariamente rappresentato, come \"category\", \"post\" o \"attachment\".","type":"string","required":false},"object_id":{"description":"L'ID del database dell'oggetto originale che questa voce di menu rappresenta, ad esempio l'ID per gli articoli o il term_id per le categorie.","type":"integer","minimum":0,"required":false},"target":{"description":"L'attributo target dell'elemento link per questa voce di menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L'URL al quale questa voce di menu punta.","type":"string","format":"uri","required":false},"xfn":{"description":"La relazione XFN espressa nel link di questa voce di menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"I termini assegnati all'oggetto nella tassonomia nav_menu.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita i risultati basati sulle relazioni tra tassonomie multiple.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limita l'insieme dei risultati agli elementi con i termini specifici assegnati nella tassonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Se gli elementi devono essere assegnati a tutti o ad alcuni dei termini specificati.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limita l'insieme dei risultati agli elementi tranne quelli con termini specifici assegnati nella tassonomia wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Elenco degli ID dei termini","description":"Abbina i termini con gli ID elencati.","type":"array","items":{"type":"integer"}},{"title":"Query della tassonomia dell'ID del termine","description":"Esegui una query avanzata dei termini.","type":"object","properties":{"terms":{"description":"ID di termini.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"wp_pattern_category":{"description":"I termini assegnati all'articolo nella tassonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Sovrascrivi la lunghezza predefinita del riassunto.","type":"integer","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"wp_pattern_category":{"description":"I termini assegnati all'articolo nella tassonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base ad un attributo dell'oggetto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 le revisioni non si possono eliminare.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false},"wp_pattern_category":{"description":"I termini assegnati all'articolo nella tassonomia wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base ad un attributo dell'oggetto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 le revisioni non si possono eliminare.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descrizione del template.","type":"string","required":false},"status":{"description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limita all'ID articolo specificato.","type":"integer","required":false},"area":{"description":"Limita all'area della parte di template specificato.","type":"string","required":false},"post_type":{"description":"Post type da cui prendere i template.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"default":"","description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descrizione del template.","type":"string","required":false},"status":{"default":"publish","description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Lo slug del template per cui ottenere l'alternativa predefinita","type":"string","required":true},"is_custom":{"description":"Indica se un template \u00e8 personalizzato o \u00e8 parte della gerarchia di template","type":"boolean","required":false},"template_prefix":{"description":"Il prefisso del template creato. Si usa per estrarre il tipo di template principale, ad esempio da `tassonomia-libri` si estrae la `tassonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descrizione del template.","type":"string","required":false},"status":{"description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base ad un attributo dell'oggetto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 le revisioni non si possono eliminare.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descrizione del template.","type":"string","required":false},"status":{"description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"area":{"description":"Si intende quella parte o sezione del template destinata ad un uso specifico (header, footer, ecc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID di un template","type":"string","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limita all'ID articolo specificato.","type":"integer","required":false},"area":{"description":"Limita all'area della parte di template specificato.","type":"string","required":false},"post_type":{"description":"Post type da cui prendere i template.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"default":"","description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descrizione del template.","type":"string","required":false},"status":{"default":"publish","description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"area":{"description":"Si intende quella parte o sezione del template destinata ad un uso specifico (header, footer, ecc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Lo slug del template per cui ottenere l'alternativa predefinita","type":"string","required":true},"is_custom":{"description":"Indica se un template \u00e8 personalizzato o \u00e8 parte della gerarchia di template","type":"boolean","required":false},"template_prefix":{"description":"Il prefisso del template creato. Si usa per estrarre il tipo di template principale, ad esempio da `tassonomia-libri` si estrae la `tassonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"slug":{"description":"Slug univoco che identifica il template.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificatore del tema per il template.","type":"string","required":false},"type":{"description":"Tipo di template.","type":"string","required":false},"content":{"description":"Contenuto del template.","type":["object","string"],"properties":{"raw":{"description":"Contenuto per il template, come riportato nel database.","type":"string","context":["view","edit"]},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dal template.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titolo del template.","type":["object","string"],"properties":{"raw":{"description":"Il titolo del template, come riportato nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per il template, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descrizione del template.","type":"string","required":false},"status":{"description":"Stato del template.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"area":{"description":"Si intende quella parte o sezione del template destinata ad un uso specifico (header, footer, ecc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L'ID di un template","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore della revisione degli stili globali.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione degli stili globali.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L'identificatore del tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L'identificatore del tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID per la configurazione degli stili globali.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Stili globali.","type":["object"],"required":false},"settings":{"description":"Impostazioni globali.","type":["object"],"required":false},"title":{"description":"Titolo della variante degli stili globali.","type":["object","string"],"properties":{"raw":{"description":"Titolo per la variante degli stili globali, se presente nel database.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base ad un attributo dell'oggetto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L'ID per il genitore della revisione.","type":"integer","required":false},"id":{"description":"Identificatore univoco per la revisione.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 le revisioni non si possono eliminare.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Versione dello schema theme.json usato per le impostazioni tipografiche.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"dichiarazione font-family in formato theme.json, codificato come una stringa.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"theme_json_version":{"description":"Versione dello schema theme.json usato per le impostazioni tipografiche.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"dichiarazione font-family in formato theme.json, codificato come una stringa.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L'ID della famiglia di font genitore del font.","type":"integer","required":true},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"L'ID della famiglia di font genitore del font.","type":"integer","required":true},"theme_json_version":{"description":"Versione dello schema theme.json usato per le impostazioni tipografiche.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"dichiarazione di font-face in formato theme.json codificata come stringa.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L'ID della famiglia di font genitore del font.","type":"integer","required":true},"id":{"description":"Identificatore univoco per il font.","type":"integer","required":true},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"L'ID della famiglia di font genitore del font.","type":"integer","required":true},"id":{"description":"Identificatore univoco per il font.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/activity-log-events":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/activity-log-events"}]}},"\/wp\/v2\/activity-log-events\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/activity-log-events\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}}]},"\/wp\/v2\/activity-log-events\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/jp_pay_order":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/jp_pay_order"}]}},"\/wp\/v2\/jp_pay_order\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Sovrascrivi la lunghezza predefinita del riassunto.","type":"integer","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"excerpt":{"description":"Il riassunto dell'articolo.","type":"object","properties":{"raw":{"description":"Il riassunto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Riassunto HTML per l'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Indica se il riassunto sia protetto da password.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/jp_pay_product":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita l'insieme dei risultati a risorse pubblicate dopo una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limita l'insieme dei risultati agli articoli pubblicati dopo una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limita la serie di risultati agli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Garantisce che la serie di risultati escluda gli articoli assegnati ad autori specifici.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita l'insieme dei risultati a risorse pubblicate prima di una data fornita nello standard ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limita l'insieme dei risultati agli articoli pubblicati prima di una determinata data conforme allo standard ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Come interpretare l'input di ricerca.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 slug specifici.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limita l'insieme dei risultati agli articoli con uno o pi\u00f9 stati assegnati.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","email_sent","email_failed","email_scheduled","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"spay_price":{"type":"number","title":"","description":"Pagamenti facili; prezzo.","default":0},"spay_currency":{"type":"string","title":"","description":"Pagamenti facili; codice valuta.","default":""},"spay_cta":{"type":"string","title":"","description":"Pagamenti facili; testo con &quot;Compra&quot; o altre CTA","default":""},"spay_multiple":{"type":"boolean","title":"","description":"Pagamenti facili; consenti pi\u00f9 elementi","default":false},"spay_email":{"type":"string","title":"","description":"Pulsante Pagamenti facili; e-mail PayPal.","default":""},"spay_status":{"type":"string","title":"","description":"Pagamenti facili; stato.","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/jp_pay_product"}]}},"\/wp\/v2\/jp_pay_product\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"spay_price":{"type":"number","title":"","description":"Pagamenti facili; prezzo.","default":0},"spay_currency":{"type":"string","title":"","description":"Pagamenti facili; codice valuta.","default":""},"spay_cta":{"type":"string","title":"","description":"Pagamenti facili; testo con &quot;Compra&quot; o altre CTA","default":""},"spay_multiple":{"type":"boolean","title":"","description":"Pagamenti facili; consenti pi\u00f9 elementi","default":false},"spay_email":{"type":"string","title":"","description":"Pulsante Pagamenti facili; e-mail PayPal.","default":""},"spay_status":{"type":"string","title":"","description":"Pagamenti facili; stato.","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"ID univoco per l'articolo.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false}}}]},"\/wp\/v2\/jp_pay_product\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"date":{"description":"La data di pubblicazione dell'articolo, nel fuso orario del sito.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione dell'articolo, nel fuso orario GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificatore alfanumerico per l'articolo unico di questo tipo.","type":"string","required":false},"status":{"description":"Uno stato con nome per l'articolo.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una password per proteggere l'accesso al contenuto e al riassunto.","type":"string","required":false},"title":{"description":"Il titolo dell'articolo.","type":"object","properties":{"raw":{"description":"Il titolo dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Titolo HTML per l'articolo, trasformato per la visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Il contenuto dell'articolo.","type":"object","properties":{"raw":{"description":"Il contenuto dell'articolo, come riportato nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML dell'articolo, trasformato per essere visualizzato.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versione del formato del blocco di contenuto utilizzata dall'articolo.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Se il contenuto \u00e8 protetto da password oppure no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L'ID dell'autore dell'articolo.","type":"integer","required":false},"featured_media":{"description":"L'id del media in evidenza per l'articolo.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"spay_price":{"type":"number","title":"","description":"Pagamenti facili; prezzo.","default":0},"spay_currency":{"type":"string","title":"","description":"Pagamenti facili; codice valuta.","default":""},"spay_cta":{"type":"string","title":"","description":"Pagamenti facili; testo con &quot;Compra&quot; o altre CTA","default":""},"spay_multiple":{"type":"boolean","title":"","description":"Pagamenti facili; consenti pi\u00f9 elementi","default":false},"spay_email":{"type":"string","title":"","description":"Pulsante Pagamenti facili; e-mail PayPal.","default":""},"spay_status":{"type":"string","title":"","description":"Pagamenti facili; stato.","default":""}},"required":false},"template":{"description":"Il file del tema da utilizzare per visualizzare l'articolo.","type":"string","required":false}}}]},"\/wp\/v2\/jp_pay_product\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L'ID del genitore del salvataggio automatico.","type":"integer","required":false},"id":{"description":"L'ID per il salvataggio automatico.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Un identificativo alfanumerico per il tipo di contenuto (post type).","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Un identificativo alfanumerico per lo stato.","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limita i risultati alle tassonomie associate ad uno specifico tipo di contenuto (post type).","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Un identificativo alfanumerico per la tassonomia.","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta per attributo del termine.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se vuoi nascondere i termini non assegnati ad alcun articolo.","type":"boolean","default":false,"required":false},"parent":{"description":"Limita la serie di risultati ai termini assegnati ad uno specifico genitore.","type":"integer","required":false},"post":{"description":"Limita la serie di risultati ai termini assegnati ad uno specifico articolo.","type":"integer","default":null,"required":false},"slug":{"description":"Limita l'insieme dei risultati ai termini con uno o pi\u00f9 specifici slug.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":true},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"parent":{"description":"L'ID del termine genitore.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":false},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"parent":{"description":"L'ID del termine genitore.","type":"integer","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 i termini non si possono eliminare.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta per attributo del termine.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se vuoi nascondere i termini non assegnati ad alcun articolo.","type":"boolean","default":false,"required":false},"post":{"description":"Limita la serie di risultati ai termini assegnati ad uno specifico articolo.","type":"integer","default":null,"required":false},"slug":{"description":"Limita l'insieme dei risultati ai termini con uno o pi\u00f9 specifici slug.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":true},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":false},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 i termini non si possono eliminare.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta per attributo del termine.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se vuoi nascondere i termini non assegnati ad alcun articolo.","type":"boolean","default":false,"required":false},"post":{"description":"Limita la serie di risultati ai termini assegnati ad uno specifico articolo.","type":"integer","default":null,"required":false},"slug":{"description":"Limita l'insieme dei risultati ai termini con uno o pi\u00f9 specifici slug.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":true},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"locations":{"description":"Le posizioni assegnate al menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se aggiungere automaticamente le pagine di primo livello a questo menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":false},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false},"locations":{"description":"Le posizioni assegnate al menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Se aggiungere automaticamente le pagine di primo livello a questo menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 i termini non si possono eliminare.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta per attributo del termine.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Se vuoi nascondere i termini non assegnati ad alcun articolo.","type":"boolean","default":false,"required":false},"post":{"description":"Limita la serie di risultati ai termini assegnati ad uno specifico articolo.","type":"integer","default":null,"required":false},"slug":{"description":"Limita l'insieme dei risultati ai termini con uno o pi\u00f9 specifici slug.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":true},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"description":{"description":"Descrizione HTML del termine.","type":"string","required":false},"name":{"description":"Il titolo HTML del termine.","type":"string","required":false},"slug":{"description":"Un identificatore alfanumerico per il termine, unico nella sua tipologia.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificativo unico per il termine.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Deve essere true, poich\u00e9 i termini non si possono eliminare.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"default":"asc","description":"Attributo per l'ordinamento ascendente o discendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordina la raccolta per l'attributo dell'utente.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limita l'insieme dei risultati agli utenti con uno o pi\u00f9 specifici slug.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limita la serie di risultati agli utenti che corrispondono ad almeno uno dei ruoli indicati. Pu\u00f2 accettare un elenco csv o un singolo ruolo.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limite di risultati impostato per gli utenti che corrispondono ad almeno una capacit\u00e0 specifica fornita. Accetta elenco CSV o capacit\u00e0 singola.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limita il risultato impostato agli utenti che sono considerati autori.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limita il risultato impostato agli utenti che hanno pubblicato degli articoli.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","jp_act_log_event":"jp_act_log_event","jp_pay_order":"jp_pay_order","jp_pay_product":"jp_pay_product"}},"required":false},"search_columns":{"default":[],"description":"Array di nomi di colonna da cercare.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Il nome per l'accesso dell'utente.","type":"string","required":true},"name":{"description":"Visualizza il nome dell'utente.","type":"string","required":false},"first_name":{"description":"Il nome dell'utente.","type":"string","required":false},"last_name":{"description":"Il cognome dell'utente.","type":"string","required":false},"email":{"description":"L'indirizzo email per l'utente.","type":"string","format":"email","required":true},"url":{"description":"L'URL dell'utente.","type":"string","format":"uri","required":false},"description":{"description":"La descrizione dell'utente.","type":"string","required":false},"locale":{"description":"La lingua per l'utente.","type":"string","enum":["","en_US","it_IT"],"required":false},"nickname":{"description":"Il nickname per l'utente.","type":"string","required":false},"slug":{"description":"Un identificatore alfanumerico per l'utente.","type":"string","required":false},"roles":{"description":"Ruoli assegnati all'utente.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password per l'utente (mai inclusa).","type":"string","required":true},"meta":{"description":"Campi dei meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Le preferenze di data e ora sono state aggiornate.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true},"jetpack_donation_warning_dismissed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificatore univoco per l'utente.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificatore univoco per l'utente.","type":"integer","required":false},"username":{"description":"Il nome per l'accesso dell'utente.","type":"string","required":false},"name":{"description":"Visualizza il nome dell'utente.","type":"string","required":false},"first_name":{"description":"Il nome dell'utente.","type":"string","required":false},"last_name":{"description":"Il cognome dell'utente.","type":"string","required":false},"email":{"description":"L'indirizzo email per l'utente.","type":"string","format":"email","required":false},"url":{"description":"L'URL dell'utente.","type":"string","format":"uri","required":false},"description":{"description":"La descrizione dell'utente.","type":"string","required":false},"locale":{"description":"La lingua per l'utente.","type":"string","enum":["","en_US","it_IT"],"required":false},"nickname":{"description":"Il nickname per l'utente.","type":"string","required":false},"slug":{"description":"Un identificatore alfanumerico per l'utente.","type":"string","required":false},"roles":{"description":"Ruoli assegnati all'utente.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password per l'utente (mai inclusa).","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Le preferenze di data e ora sono state aggiornate.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true},"jetpack_donation_warning_dismissed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificatore univoco per l'utente.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"\u00c8 necessario che sia impostato su vero, se la risorsa non supporta l'eliminazione.","required":false},"reassign":{"type":"integer","description":"Assegna gli articoli e i link dell'utente eliminato all'utente con questo ID.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Il nome per l'accesso dell'utente.","type":"string","required":false},"name":{"description":"Visualizza il nome dell'utente.","type":"string","required":false},"first_name":{"description":"Il nome dell'utente.","type":"string","required":false},"last_name":{"description":"Il cognome dell'utente.","type":"string","required":false},"email":{"description":"L'indirizzo email per l'utente.","type":"string","format":"email","required":false},"url":{"description":"L'URL dell'utente.","type":"string","format":"uri","required":false},"description":{"description":"La descrizione dell'utente.","type":"string","required":false},"locale":{"description":"La lingua per l'utente.","type":"string","enum":["","en_US","it_IT"],"required":false},"nickname":{"description":"Il nickname per l'utente.","type":"string","required":false},"slug":{"description":"Un identificatore alfanumerico per l'utente.","type":"string","required":false},"roles":{"description":"Ruoli assegnati all'utente.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Password per l'utente (mai inclusa).","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Le preferenze di data e ora sono state aggiornate.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true},"jetpack_donation_warning_dismissed":{"type":"boolean","title":"","description":"","default":false}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"\u00c8 necessario che sia impostato su vero, se la risorsa non supporta l'eliminazione.","required":false},"reassign":{"type":"integer","description":"Assegna gli articoli e i link dell'utente eliminato all'utente con questo ID.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Un UUID fornito dall'applicazione per una identificazione univoca. Si raccomanda di usare un UUID v5 con l'URL o il namespace DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Il nome della password dell'applicazione.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Un UUID fornito dall'applicazione per una identificazione univoca. Si raccomanda di usare un UUID v5 con l'URL o il namespace DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Il nome della password dell'applicazione.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"after":{"description":"Limita la risposta ai commenti pubblicati dopo una specifica data conforme al formato ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limita l'insieme dei risultati ai commenti assegnati a specifici id utenti. Richiede una autorizzazione.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Esclude dall'insieme dei risultati i commenti provenienti da specifici id di autori. Richiede una autorizzazione.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limita l'insieme dei risultati a quelli provenienti da uno specifico indirizzo email di un autore. Richiede una autorizzazione.","format":"email","type":"string","required":false},"before":{"description":"Limita la risposta ai commenti pubblicati prima di una specifica data conforme al formato ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la collezione in base a un attributo del commento.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limita l'insieme dei risultati alle risorse appartenenti a specifici ID genitore.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Esclude dall'insieme dei risultati gli elementi con l'ID genitore specificato.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limita l'insieme dei risultati ai commenti assegnati a specifici ID di articoli.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limita l'insieme dei risultati ai commenti con uno specifico stato assegnato. Richiede una autorizzazione.","type":"string","required":false},"type":{"default":"comment","description":"Limita l'insieme dei risultati a commenti assegnati ad un tipo specifico. Richiede autorizzazione.","type":"string","required":false},"password":{"description":"La password per l\u2019articolo se fosse protetto da password.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"L'id dell'oggetto user, se l'autore \u00e8 stato un utente.","type":"integer","required":false},"author_email":{"description":"Indirizzo email dell'autore del commento.","type":"string","format":"email","required":false},"author_ip":{"description":"Indirizzo IP dell'autore del commento.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome pubblico visualizzato per l'autore del commento.","type":"string","required":false},"author_url":{"description":"L\u2019URL dell\u2019autore del commento.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User agent dell'autore del commento.","type":"string","required":false},"content":{"description":"Il contenuto del commento.","type":"object","properties":{"raw":{"description":"Il contenuto del commento, come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML del commento, adattato alla visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La data in cui il commento \u00e8 stato pubblicato, nel fuso orario del sito web.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione del commento, nel fuso orario GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"L'ID del genitore del commento.","type":"integer","required":false},"post":{"default":0,"description":"L'id dell'oggetto articolo associato.","type":"integer","required":false},"status":{"description":"Stato del commento.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Stato di risoluzione delle note","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID univoco per il commento.","type":"integer","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La password per l'articolo genitore del commento (se l'articolo \u00e8 protetto con password).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID univoco per il commento.","type":"integer","required":false},"author":{"description":"L'id dell'oggetto user, se l'autore \u00e8 stato un utente.","type":"integer","required":false},"author_email":{"description":"Indirizzo email dell'autore del commento.","type":"string","format":"email","required":false},"author_ip":{"description":"Indirizzo IP dell'autore del commento.","type":"string","format":"ip","required":false},"author_name":{"description":"Nome pubblico visualizzato per l'autore del commento.","type":"string","required":false},"author_url":{"description":"L\u2019URL dell\u2019autore del commento.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User agent dell'autore del commento.","type":"string","required":false},"content":{"description":"Il contenuto del commento.","type":"object","properties":{"raw":{"description":"Il contenuto del commento, come presente nel database.","type":"string","context":["edit"]},"rendered":{"description":"Contenuto HTML del commento, adattato alla visualizzazione.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La data in cui il commento \u00e8 stato pubblicato, nel fuso orario del sito web.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La data di pubblicazione del commento, nel fuso orario GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"L'ID del genitore del commento.","type":"integer","required":false},"post":{"description":"L'id dell'oggetto articolo associato.","type":"integer","required":false},"status":{"description":"Stato del commento.","type":"string","required":false},"meta":{"description":"Campi dei meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Stato di risoluzione delle note","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"ID univoco per il commento.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se evitare il cestino e eliminare definitivamente.","required":false},"password":{"description":"La password per l'articolo genitore del commento (se l'articolo \u00e8 protetto con password).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"type":{"default":"post","description":"Limita i risultati agli elementi di un tipo di oggetto.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limita i risultati agli elementi di uno o pi\u00f9 sottotipi di oggetti.","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Esclude specifici ID dall'insieme dei risultati.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limita l'insieme dei risultati a specifici ID.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nome univoco registrato per il blocco.","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attributi del blocco.","type":"object","default":[],"required":false},"post_id":{"description":"ID del contesto dell'articolo.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace del blocco.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Namespace del blocco.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nome del blocco.","type":"string","required":false},"namespace":{"description":"Namespace del blocco.","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"jetpack_ai_agents_enabled":{"title":"","description":"Se l'accesso agli agenti IA \u00e8 abilitato su questo sito.","type":"boolean","required":false},"title":{"title":"Titolo","description":"Titolo del sito.","type":"string","required":false},"description":{"title":"Motto","description":"Motto del sito.","type":"string","required":false},"url":{"title":"","description":"URL del sito.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Questo indirizzo \u00e8 utilizzato per scopi amministrativi, come ad esempio la notifica dell'iscrizione di nuovi utenti.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Una citt\u00e0 nel tuo stesso fuso orario.","type":"string","required":false},"date_format":{"title":"","description":"Un formato per tutte le stringhe che rappresentano una data.","type":"string","required":false},"time_format":{"title":"","description":"Un formato per tutte le stringhe che rappresentano un orario.","type":"string","required":false},"start_of_week":{"title":"","description":"Il numero del giorno della settimana in cui la settimana dovrebbe cominciare.","type":"integer","required":false},"language":{"title":"","description":"Codice locale di WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Visualizza gli emoticon tipo :-) e :-P come simboli grafici.","type":"boolean","required":false},"default_category":{"title":"","description":"Categoria predefinita per gli articoli.","type":"integer","required":false},"default_post_format":{"title":"","description":"Formato dell'articolo predefinito.","type":"string","required":false},"posts_per_page":{"title":"Numero massimo di articoli per pagina","description":"Pagine del blog da mostrare al massimo.","type":"integer","required":false},"show_on_front":{"title":"Visualizza sul fronte","description":"Cosa mostrare nella pagina principale","type":"string","required":false},"page_on_front":{"title":"Pagina sul fronte","description":"L'ID della pagina che dovrebbe essere mostrata nella home page","type":"integer","required":false},"page_for_posts":{"title":"","description":"L'ID della pagina che dovrebbe visualizzare gli articoli pi\u00f9 recenti","type":"integer","required":false},"default_ping_status":{"title":"","description":"Consenti notifiche di link da altri blog (pingback e trackback) sui nuovi articoli.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Permetti commenti sui nuovi articoli","description":"Permetti di commentare i nuovi articoli.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo del sito.","type":"integer","required":false},"site_icon":{"title":"Icona","description":"Icona del sito.","type":"integer","required":false},"jetpack_search_ai_behavior_instructions":{"title":"","description":"","type":"string","required":false},"cookie_consent_template":{"title":"","description":"","type":"string","required":false},"Blogroll Recommendations":{"title":"","description":"Consigli per il sito","type":"array","items":{"type":"object","properties":{"id":{"type":"string","format":"text-field"},"name":{"type":"string","format":"text-field"},"icon":{"type":"string","format":"uri"},"url":{"type":"string","format":"uri"},"description":{"type":"string","format":"text-field"},"is_non_wpcom_site":{"type":"boolean"}},"additionalProperties":false},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limita il risultato impostato sui temi assegnati ad uno o pi\u00f9 stati.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Il foglio di stile del tema. Questo identifica in modo univoco il tema.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","required":false},"status":{"description":"Limita i risultati ai plugin con il seguente stato.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug del plugin nella directory di WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Lo stato di attivazione del plugin.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Lo stato di attivazione del plugin.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L'id di una barra laterale registrata","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widget annidati.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L'ID del tipo di widget.","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L'ID del tipo di widget.","type":"string","required":true},"instance":{"description":"Impostazioni dell'istanza attuale del widget.","type":"object","required":false},"form_data":{"description":"Dati serializzati del modulo del widget da codificare nelle impostazioni dell'istanza.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L'ID del tipo di widget.","type":"string","required":true},"instance":{"description":"Impostazioni dell'istanza attuale del widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"La barra laterale per cui restituire i widget.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificatore univoco del widget.","type":"string","required":false},"id_base":{"description":"Il tipo del widget. Corrisponde all'ID nell'endpoint widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"La barra laterale a cui appartiene il widget.","type":"string","required":true},"instance":{"description":"Istanza delle impostazioni del widget, se supportato.","type":"object","properties":{"encoded":{"description":"Rappresentazione codificata in base64 dell'istanza delle impostazioni.","type":"string","context":["edit"]},"hash":{"description":"Hash crittografato dell'istanza delle impostazioni.","type":"string","context":["edit"]},"raw":{"description":"Istanza decodificata delle impostazioni, se supportato.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-codificato del modulo dei dati dal modulo amministrativo dei widget. Utilizzato per aggiornare un widget che non supporta le istanze. Sola scrittura.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificatore univoco del widget.","type":"string","required":false},"id_base":{"description":"Il tipo del widget. Corrisponde all'ID nell'endpoint widget-types.","type":"string","required":false},"sidebar":{"description":"La barra laterale a cui appartiene il widget.","type":"string","required":false},"instance":{"description":"Istanza delle impostazioni del widget, se supportato.","type":"object","properties":{"encoded":{"description":"Rappresentazione codificata in base64 dell'istanza delle impostazioni.","type":"string","context":["edit"]},"hash":{"description":"Hash crittografato dell'istanza delle impostazioni.","type":"string","context":["edit"]},"raw":{"description":"Istanza decodificata delle impostazioni, se supportato.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-codificato del modulo dei dati dal modulo amministrativo dei widget. Utilizzato per aggiornare un widget che non supporta le istanze. Sola scrittura.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Se forzare la rimozione del widget o spostarlo nella barra laterale inattiva.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limita i risultati ai blocchi che corrispondono ai termini di ricerca.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limita la serie di risultati a quelli contententi una stringa.","type":"string","minLength":1,"required":false},"category":{"description":"Limita i risultati a quelli corrispondenti all'ID della categoria.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limita i risultati a quelli corrispondenti all'ID della parola chiave.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limita i risultati a quelli che corrispondono a un pattern (slug).","type":"array","required":false},"offset":{"description":"Sposta di uno specifico numero di elementi l'inizio dell'insieme dei risultati.","type":"integer","required":false},"order":{"description":"Attributo per l'ordinamento ascendente o discendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordina la raccolta in base ad un attributo dell'articolo.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"URL da elaborare.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Un identificatore alfanumerico per la posizione del menu.","type":"string","required":false},"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identificatore univoco della categoria dell'abilit\u00e0.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identificatore univoco dell'abilit\u00e0.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Inserisci i parametri per l'esecuzione dell'abilit\u00e0.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Scopo della richiesta; determina i campi che saranno presenti nella risposta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Pagina corrente dell'elenco.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Numero massimo dei risultati da restituire nella serie dei risultati.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limita i risultati ad abilit\u00e0 in specifiche categorie di abilit\u00e0.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identificatore univoco dell'abilit\u00e0.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]}},"site_logo":0,"site_icon":0,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/www.professionistidelsuono.net\/blog_audio\/wp-json\/"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
