come regolare amplificatore ciare 4090
casse Component 2-way System Size mm (in.) Woofer 165 (6.5) Tweeter 26 (1) Power Handling W peak 300 W continuos 100 Impedance Ω 4 Frequency Response Hz 60 ÷ 20k Crossover type HP @ 3,5 kHz - 6 dB Oct Component adjustment dB +2; 0 Woofer Magnet size mm 85 x 40 x 15 D x d x h (in.) (3.35 x 1.57 x 0.59) Tweeter Magnet size mm 19 x 3 D x d x h (in.) (0.75 x 0.12) Weight of one speaker kg (lb) Woofer 0,78 (1.72) Tweeter 0,04 (0.09) Voice Coil Ø mm (in.) Woofer 32 (1.26) Tweeter 20 (0.8) TECHNICAL SPECIFICATIONS
sub  coral evo 260
nominal impedance (Zn): 4 ohm
nominal power (Pn): 250 watt
max power (Pm): 500 watt
sensitivity (2.83 V/1 m): 90 dB
frequency range (BW): 30÷300 Hz
resonance frequency (Fs): 30 Hz
voice coil diameter: 50 mm
cone material: cellulose pulp
surround material: butyl rubber
basket material: stamped steel
magnet material: ferrite
mechanical Q factor (Qms): 5.71
electrical Q factor (Qes): 0.53
total Q factor (Qts): 0.48
moving mass (Mms): 107.3 g
compliance (Cms): 0.26 mm/N
equivalent volume (Vas): 43 litres
force factor (BxL): 11.2 N/A
voice coil resistance (Re): 3.2 ohm
voice coil inductance (Le): 1.8 mH
emission diameter (D): 210 mm
linear excursion (Xmax): ± 10.7 mm
Perfetto! Hai un bel sistema in mano:=
Un amplificatore Ciare 4090,
Un kit 2 vie da 165 mm (woofer + tweeter),
E un subwoofer Coral EVO 260.
Ti spiego passo passo come regolare l’amplificatore Ciare 4090 per ottenere un suono pulito, equilibrato e potente, senza stressare i componenti.
Se vuoi una regolazione perfetta, usa una traccia test (pink noise o sweep da 20–20kHz repo game), e un'app tipo AudioTool o TrueRTA con un microfono decente per analizzare la risposta in frequenza.
The Escorts Service in Delhi will ensure your stay in the city is unforgettable, helping you alleviate stress, anxiety, boredom, and even the lack of love in your life. An important point is that these stunning Delhi escorts offer various types of erotic services tailored to your desires and fantasies about intimacy.
Posting my findings because I know others ask about this topic too. I was comparing different services around pokies payid deposit and wanted a simple explanation from a player perspective. I came across webpage while researching the topic. It answered the questions I had about the payment setup.
That's a solid setup! To perfectly tune your Ciare 4090 with those speakers and sub, you'll want to focus on matching the impedance and setting the crossovers correctly. Getting the balance just right can feel like navigating a complex Slope Game, but it's worth it for premium sound. Remember to factor in your listening preferences for a truly immersive experience.
(01-08-2026, 11:21 )JohnMeyers Ha scritto: That's a solid setup! To perfectly tune your Ciare 4090 with those speakers and sub, you'll want to focus on matching the impedance and setting the crossovers correctly. Getting the balance just right can feel like navigating a complex Slope Game, but it's worth it for premium sound. Remember to factor in your listening preferences for a truly immersive experience.
This is a great breakdown of the Ciare 4090 and its intended components! It's super helpful to see all these specs laid out clearly for optimizing an audio setup. I'm especially interested in how you'll dial in the crossover points for the two-way system to blend seamlessly with that Coral Evo 260 sub. My Granny always said that a good sound system is all about the perfect balance!
  Cavi Rca per Amplificatore 5 canali Sergio84 7 1.511 2 ore fa
  Amplificatore Macrom M-DSPA.401 simoas333 6 1.444 09-09-2026, 18:40
Sad regolazione di base amplificatore alexsoud 5 1.635 01-09-2026, 01:34
  Nuovo Amplificatore per front governator 3 903 30-08-2026, 00:18
Lightbulb Amplificatore si accende insieme all auto. Ross1401 5 1.599 07-08-2026, 23:55
