come regolare amplificatore ciare 4090
casse Component 2-way System Size mm (in.) Woofer 165 (6.5) Tweeter 26 (1) Power Handling W peak 300 W continuos 100 Impedance Ω 4 Frequency Response Hz 60 ÷ 20k Crossover type HP @ 3,5 kHz - 6 dB Oct Component adjustment dB +2; 0 Woofer Magnet size mm 85 x 40 x 15 D x d x h (in.) (3.35 x 1.57 x 0.59) Tweeter Magnet size mm 19 x 3 D x d x h (in.) (0.75 x 0.12) Weight of one speaker kg (lb) Woofer 0,78 (1.72) Tweeter 0,04 (0.09) Voice Coil Ø mm (in.) Woofer 32 (1.26) Tweeter 20 (0.8) TECHNICAL SPECIFICATIONS
sub  coral evo 260
nominal impedance (Zn): 4 ohm
nominal power (Pn): 250 watt
max power (Pm): 500 watt
sensitivity (2.83 V/1 m): 90 dB
frequency range (BW): 30÷300 Hz
resonance frequency (Fs): 30 Hz
voice coil diameter: 50 mm
cone material: cellulose pulp
surround material: butyl rubber
basket material: stamped steel
magnet material: ferrite
mechanical Q factor (Qms): 5.71
electrical Q factor (Qes): 0.53
total Q factor (Qts): 0.48
moving mass (Mms): 107.3 g
compliance (Cms): 0.26 mm/N
equivalent volume (Vas): 43 litres
force factor (BxL): 11.2 N/A
voice coil resistance (Re): 3.2 ohm
voice coil inductance (Le): 1.8 mH
emission diameter (D): 210 mm
linear excursion (Xmax): ± 10.7 mm
Perfetto! Hai un bel sistema in mano:=
Un amplificatore Ciare 4090,
Un kit 2 vie da 165 mm (woofer + tweeter),
E un subwoofer Coral EVO 260.
Ti spiego passo passo come regolare l’amplificatore Ciare 4090 per ottenere un suono pulito, equilibrato e potente, senza stressare i componenti.
Se vuoi una regolazione perfetta, usa una traccia test (pink noise o sweep da 20–20kHz repo game), e un'app tipo AudioTool o TrueRTA con un microfono decente per analizzare la risposta in frequenza.
Posting my findings because I know others ask about this topic too. I was comparing different services around pokies payid deposit and wanted a simple explanation from a player perspective. I came across webpage while researching the topic. It answered the questions I had about the payment setup.
How to adjust the Ciare 4090 amplifier is so nice and there are a lot of people using these updates and we are here to learn more to get the right updates that are bringing the best results to us. When I try the fence repair solutions, I saw it was bringing the best results to us. People like to learn how it can bring the desired results. When I used fence repair I got the best results. These are the options we are dealing with to find the desired results.
  Amplificatore Macrom M-DSPA.401 simoas333 4 1.461 09-09-2026, 18:40
  Nuovo Amplificatore per front governator 3 921 30-08-2026, 00:18
  Cavi Rca per Amplificatore 5 canali Sergio84 2 1.540 16-07-2026, 18:32
  amplificatore fuori uso goku_db 4 2.041 20-06-2026, 21:17
  Amplificatore 4ch per barca open giaklegend 8 2.960 29-05-2026, 04:30
