LANZAR ...BUONA MARCA???
CHE NE DITE DI QUESTO AMPLIFICATORE????
[Immagine: 2007141635_vibe286.jpg]
37,73 KB
LANZAR VIBE286 AMPLIFICATORE 2 CANALI 4000WATT
QUESTO FANTASTICO AMPLIFICATORE LANZAR 2 CANALI CLASSE AB E IN GRADO DI EROGARE BEN 4000 WATT. E PUO ESSERE UTILIZZATO IN MONO PER AMPLIFICARE UN SUBWOOFER O IN STEREO PER GLI ALTOPARLANTI. INOLTRE E IN GRADO DI SCENDERE FINO AD UNA IMPEDENZA DI 2 OHM. QUINDI E POSSIBILE COLLEGARE FINO A 4 ALTOPARLANTI. FANTASTICO AMPLIFICATORE DELLA FAMOSISSIMA LANZAR VIBE!!! AMPLIFICATORI TOP GAMMA LANZAR DI ALTISSIMA QUALITA ED ELEVATA POTENZA
CARATTERISTICHE TECNICHE:
2 x 1000W RMS at 4 OHMS 2 x 2000W MAX at 4 OHMS
1 x 4000W MAX at 4 OHMS Bridged 2 x 1650W at 2 OHMS RMS
Electronic Crossover Network
Bass Boost Circuit
2 Ohms Stereo Stable
Anti-Thump Turn-On
Illuminated Top Panel
Soft Turn On/Off
High & Low Level Inputs
Power & Protection LED Indicators
Advanced Protection Circuitry
Remote Control Bass Booster
THD: <0.04%
S/N Ratio: >90dB
Channel Separation: >65dB
Freq. Response: 15Hz~35kHz
Dimensions: 11.06''W x 2.24''H x 21''L
  Consiglio impianto fiat punto di buona qualità Luintegrale98 6 2.929 01-05-2017, 21:39
  Batteria Ursus 100ah, buona ? thebestluis 9 8.135 11-02-2015, 22:19
  Impianto hifi Lanzar per mazda mx5 opinioni LotusGiorgio 34 19.175 16-10-2014, 07:42
  marca non ancora nota drag♧Racers 10 4.676 07-08-2014, 01:36
  buona configurazione? slay 4 2.033 07-02-2013, 08:00
