casa reflex per sub 39 cm
ciao volevo sapere se qualcuno mi poteva dare le dimensioni per la cassa in reflex per un sub di 39 cm della target audio..
grazie mille
almeno dacci i parametri....
Subwoofer, diametro 260 mm, 175 watt nominali, 300 watt max, cono in polipropilene placcato color titanio, sospensione in gomma butilica, piastre polari cromate, morsetti a vite
TECHNICAL DATA:
nominal impedance (Zn): 4 ohm
nominal power (Pn): 175 watt
max power (Pm): 350 watt
sensitivity (2.83 V/1 m): 91 dB
frequency range (BW): 35÷2000 Hz
resonance frequency (Fs): 35 Hz
voice coil diameter: 50 mm
cone material: polypropylene
surround material: butyl rubber
basket material: stamped steel
magnet material: ferrite
mechanical Q factor (Qms): 3.26
electrical Q factor (Qes): 0.48
total Q factor (Qts): 0.42
moving mass (Mms): 55.2 g
compliance (Cms): 0.32 mm/N
equivalent volume (Vas): 55 litres
force factor (BxL): 10 N/A
voice coil resistance (Re): 3.4 ohm
voice coil inductance (Le): 0.8 mH
emission diameter (D): 210 mm
linear excursion (Xmax): ± 4 mm
MA perche prima dici che è un 39cm di diametro e nei parametri è un 25?
La sigla del sub qual'è?
ops ho sbagliato prendere i dai scusate adesso metto quelli giusti...sorry
la target audio di solito consiglia dei progetti...controlla bene sul sito e segui la cassa consigliata dalla casa
TLS 15
Subwoofer 390 mm
Subwoofer, diametro 390 mm, 300 watt nominali, 600 watt max, cono in polipropilene placcato color titanio, sospensione in gomma butilica, piastre polari cromate, morsetti a vite
TECHNICAL DATA:
nominal power (Pn): 300 watt
max power (Pm): 600 watt
sensitivity (2.83 V/1 m): 92 dB
frequency range (BW): 25÷2000 Hz
resonance frequency (Fs): 23 Hz
voice coil diameter: 65 mm
mechanical Q factor (Qms): 3.04
electrical Q factor (Qes): 0.81
total Q factor (Qts): 0.64
moving mass (Mms): 158.3 g
compliance (Cms): 0.29 mm/N
equivalent volume (Vas): 303 litres
force factor (BxL): 9.9 N/A
voice coil inductance (Le): 0.4 mH
emission diameter (D): 330 mm
linear excursion (Xmax): ± 6 mm
Presumendo quindi che sia il modello TLS 10 da 260mm (non 390mm) cè proprio il link sul sito per costruire il box, basta cercare.
http://www.targetaudio.it/upload/recensi...TLS_10.pdf
lo so che c'è il progetto ma è in cassa chiusa...
e in cassa chiusa l'ho gia ma suona male..
ho chiesto a un mio socio e mi ha detto che sarebbe meglio in reflex..
però non mi ha dato le misure per fare la cassa
E allora se è il TLS15 cè sempre tutto li.
http://www.targetaudio.it/upload/recensi...TLS_15.pdf
  Box reflex per subwoofer 15" montato al contrario rafracing 1 5.645 06-11-2026, 09:44
  calcolo cassa reflex germano 5 2.291 06-05-2026, 16:12
  Box reflex per audison av12 davi5193 2 2.125 15-03-2022, 21:33
  Costruzione cassa reflex hertz HX 380 matt89 7 3.277 24-03-2021, 02:53
  Box reflex hertz HXS 380D Golfmk3 2 1.114 03-03-2021, 01:56
